truma ultrastore rapid (1 Viewer)
Feb 16, 2013
19,727
51,988
uttoxeter
ambulance conversion
50 years
Hi all
New on here but not to camper vans and motorhomes, done it most of my life but mainly in old ones I keep going by myself. But now I am retired thought I would go modern and bought a compass avantgarde. Now the reason I am posting on here is I have a bit of a niggle with the water heater which works fine except for a drip out of the vent pipe in a morning , maybe a pint every two hours, if you run the hot tap it stops and useing it through the day it doesnt drip again but it will be dripping again next morning even with the burner switched off. Is this normal , if not , what do I need to do to stop it.
Thanks chaser
Ash
Trader - Service & Repairs
788
217
Chapel st Leonard's. Lincolnshire
Hi all
Thanks chaser
Sounds like your none return valve is not working :thumb:
If you need advice give me a call tomorrow
Ash tel 07976167477 :thumb:
chaser
Feb 16, 2013
19,727
51,988
uttoxeter
50 years
Cheers mate, thought so but not having anything to do with these type of boilers thought i'd ask someone that knows before I messed with it.
Chaser
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Faulty non return valve (the red bit on the ho water outlet at top of boiler. Not an expensive part but make sure you get the right one as there are two types. One has a john guest push in fitting for the hot water pipe and the other has a ribbed spigot to go into the hot water hose with a jubilee clip to hold it on.
D.
chaser
Feb 16, 2013
19,727
51,988
uttoxeter
50 years
Hi Guys
First thing this morning , ordered new fitting, went to get old one off, guess what , just a little rubber valve with a bit off muck stuck in it, cleaned it up , not a speck of water comeing out.:Doh:. Still got a spare now if it goes wrong.
Thanks again for your help
chaser
