Truma heating problem (1 Viewer)
Plup
4
Naas Ireland
A class tag axle
since 2005
Hi. We have a problem with our Truma water heater in our Frankia which we have just purchased. We were trying to get the heating working on 240v electric dial but didnt seem to work. We checked the automatic overheating switch which seemed to be OK. The drain valve had accidentley opened and we could not close it manually and stop the water from draining even whilst filling. Does this valve run off a fuse? We followed the instructions on the manual but still cant get the valve to close.
Any help appreciated.
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
some drain valves have a frost protection device that drains below about 5 degrees I am sure someone will come along with more info what truma system do you have you can get info from here
http://www.trumauk.com/
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
This may be an auto drain valve
If its a lift to close type valve it may have automaticly opend as they do when temp drops below +3c (freeze protection) and they wont stay closed untill the temp reaches aprox +8c a tip is to lift plunger and place a cloths peg under it to stop it dropping down again fill up and start heating:thumb:
remove peg if putting into storage
Geo
Richard W
Jul 29, 2010
184
150
Burwash, Sussex
Just Starting
Ah, that explains it.
Hi Geo,
Many thanks, that explains what has happened to my heating / water system and why the contents of the fresh water tank got pumped overboard.
Still, with an empty tank and all the taps open I don't have to worry about the cold weather.
Quick question: Is there a risk of damage using the blown air heating if there's no water in the system with a combi Truma?
Cheers,
Richard W.
Oct 29, 2008
5,056
5,909
West Yorkshire
PVC
since 2008
Hi Geo,
Cheers,
Richard W.
It can be used without water
