Truma gas regulator problem
Discussion in 'Heating and Air-Conditioning' started by OllieUK, Dec 26, 2014.
  1. OllieUK
    OllieUK Read Only Funster
    Jun 23, 2013
    259
    297
    Ramsgate
    Pre-check today regarding gas and electric heating, I now find that I cannot get any gas (Heating, Stove, or Fridge ) to work. Checked gas propane bottles both full, pressed green reset button on regulator, checked green and blue taps inside the van were in the "On" position.
    NO gas getting through. I think I must have a defective regulator. A right bummer as I was going to have a week away from tomorrow.
    Can these regulators be serviced? or is it a replacement? that is needed.
    As an after thought would this be a good time to upgrade to a Gaslow system ?
    by the time I pay for a replacement regulator and fitting, how much would the difference in cost be?
    Can anyone give me a quote on a Gaslow system fitted please.
    • Like it Like it x 1
  2. lunarman
    lunarman Funster Life Member
    Sep 23, 2008
    1,484
    888
    South Glos
    You would still have to replace the regulator. The gaslow only replaces the bottles using the existing regulator.
  3. Wickolad
    Wickolad Funster
    Sep 10, 2013
    482
    542
    Wickersley
    Tyou could get a replacement truma regulator ( costly ) or why not just get a regular propane or butsne regulator and an adaptor to fit the hose to the system. I think the regulAr propane regulator are not as sensitive to the oil contamination from the gas bottles. There must be an adaptor to allow a push fit hose connection which should allow you to continue with your holiday plans :)
  4. Scattycat
    Scattycat Funster
    Jan 3, 2013
    844
    1,184
    Mayenne, France
    What size is the feed from your regulator to the appliences?
    I have an 8 mm one that I bought but needed a 10 mm so I could let you have the 8 mm at a good price if you're interested
  5. bobandjanie
    bobandjanie Funster Life Member
    Apr 28, 2008
    4,503
    2,609
    UK / Spain
    If you have the secumotion regulator with the button you should also have buttons to push down on your hoses near the valve on the gas bottles. :xgrin: Bob.
  6. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,757
    10,175
    the more reliable gasit or cleese regulators are only about £20
  7. OllieUK
    Jun 23, 2013
    259
    297
    Ramsgate
    I need a 10 mm,
    I didn't check the feed hose for any buttons, will look in the morning .. Thanks.
  8. Dazzlin
    Dazzlin Funster Life Member
    Oct 31, 2012
    879
    1,720
    on the road
    I will have it now ben does not want it. I used my spare a couple of weeks ago.
    We will be passing on the way back in may! If its gone by then no probs.
  9. Scattycat
    Scattycat Funster
    Jan 3, 2013
    844
    1,184
    Mayenne, France
    Timing is fortunate, we expect to be back home around the end of April.
