Truma EH6002 (1 Viewer)
Jan 3, 2008
3,329
5,340
Pakefield, Lowestoft, Suffolk, UK
Looking
I have the EH 6002 and for a while there has been a steady drip from the condense tube (Not the safety drain valve) this has become at times quite a puddle and I can see moisture in the clear tube. The water is very hot but then I suppose it should be when set on 60 degrees. The same thing happens whether on gas or electricity and having the heating on or off makes no difference. I do get the occasional small dump of water from the safety drain valve so I am wondering if the water is overheating and causing excess pressure in the system.
Has anyone experience a similar issue?
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
Hi... No we get nothing like that at all. I have seen some moisture in the clear tube on occasion.. But that's no concern and we certainly get no leak or drips. Our dump valve is manual so not an issue either
