With a red top that is the older electric one I assume then you have C6002, (round vertical mounted boiler) as said probably the relief valve at the top of the boiler. It is a red T piece it has a one way valve that lets air out when filling there will be a drain pipe from it going out under the van, if water is coming out there that's your problem.My tap is just a uprightone will trytoget photo tom , thanks all
Sounds like my Alde one. There could be a second yellow valve next to it that you twist to open or closed. If there is, is that still open?Mine is yellow up for drain down for filling and its 2007 will take photo later grandkids sleeping in there tonite bless um thanks for help.
I assume it is the boiler drain and not the fresh water tank drain that's been left open?Hi guys my boiler is still draining out in the on or off position any ideas, regards steve
As pops has saidIf you go beyond the horizontal position it will still let water out.
Leisure Shop Direct stock them.
@Lenny HB Hit the nail on the head, There is a very crude non return valve in the "red thingee" even if you drain for the winter, if there is just a tiny bit of water that freezes in there it will push the N/R/valve the other way
Best to cover Boiler with a blanket or something similar just in case of frost
Advisable if you cover your water pump too, no matter how thorough you are draining, there is always water in your filter, (the little clear plastic thingee on the end of your pump) If this freezes it can crack the filter housing.
