Truma Combi - No Hot Water - Help!
Discussion in 'Tech/Mech General' started by Toffs-G, Apr 18, 2010.
  1. Toffs-G
    Toffs-G Funster
    Sep 16, 2009
    606
    111
    West Sussex
    Hi,
    I have a Truma Combi in my MH, I have just put the water heater on and the Orange light comes on no problem to say it is heating up then when it goes out I run the hot water and it is stone cold.
    Heating is working OK
    Any thoughts on how to rectify would be greatfully appreciated
    Gary
  2. rav4girly
    rav4girly Read Only Funster
    Aug 26, 2009
    52
    Wirral
    I had the same problem when we first got our motorhome. Make sure that you have taken the cap off the vent for the boiler. When you turn it on do you hear it fire up? If you do then don't run any water for at least 30 minutes and then check it. I think we were trying the water too soon and then it was topping itself up with cold again so we never got past luke warm.
  3. Toffs-G
    Toffs-G Funster
    Sep 16, 2009
    606
    111
    West Sussex
    Thanks for that, it does fire up yes and the the orange light goes out but then i was runnng the water straight away.
    Will give it a try
    Much appreciated:thumb:
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,389
    18,079
    YO11 2BD
    got to leave it to heat the water.....its nothing more than a big kettle really, and you wouldnt make tea from a kettle which hasnt boiled...or would you!!! :Laughing:
  5. Rainbowchaser
    Rainbowchaser Read Only Funster
    Feb 27, 2010
    332
    5
    Third rock from the sun
    combi
    Hi Gary,
    Hmnn, just been looking through my manuals but no mention of your fault.
    I assume you've checked the usual things like :
    Is there water to the system.
    Have you set the temperature.
    Purged the system ie, turn all the taps on.
    Dump valve closed..
    There is mention of a slow-blow fuse in the pcb but I'd think this unlikely if you have heating.
    Other than the above, sorry, sounds like a
    call to Trauma may be in order.
    Be interested if and when you get a result
    Good luck
    Tony
  6. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,427
    5,457
    East Sussex 01-580-881288
    Hi Gary,
    If you dont have any luck, give Glenn or Ian a ring on Monday, they will know the answer.
    Peter
  7. pappajohn
    Aug 26, 2007
    30,389
    18,079
    YO11 2BD
    you two must have missed this crucial bit below then....:Doh::Rofl1:
  8. first5
    first5 Read Only Funster
    Apr 11, 2009
    13
    Newcastle upon Tyne
    It takes over an hour to heat the water or at least ours did so give it a bit of time.
