Truma boiler problem. Any advice please?
Discussion in 'Motorhome Chat' started by Gromett, Nov 11, 2012.
  1. Gromett
    Gromett Funster
    Feb 27, 2011
    8,087
    14,689
    UK
    My boiler has started playing up.
    It used to start on the first click. Now it sounds like a mini explosion is happening then sounds like a flame is flicking back and forth in a tube.
    Sort of Thud, thud, thud, thud, thud BrrrrrRRRRRR.
    Hard to explain sounds in words:Doh:
    Once a day or so it goes through the cycle and fails to ignite and the red light indicating out of gas comes on. The hob is working full blast, the gas cylinder is full....
    Does anyone have any suggestions as to what might be happening.
  2. Gromett
    Gromett Funster
    Feb 27, 2011
    8,087
    14,689
    UK
    Does anyone have access to the service manual for one of these?
    It's a Truma C4002 combi.
  3. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,351
    5,364
    East Sussex 01-580-881288
    Give Glenn or Ian a ring on 01580-883061 and pick their brains, phone might be a bit busy.
    Peter
  4. movan
    movan Funster Life Member
    Dec 2, 2009
    13,624
    24,610
    Moving around
    Mine isn't the same model, but it is a Truma ... it says in the book (quote)
    if the burner makes an unusual noise or if the flame lifts off, it is likely that the regulator is faulty and it is essential to have it checked. (end quote0
    Don't know if that is of any help.
  5. Stephen & Jeannie
    Stephen & Jeannie Read Only Funster
    Aug 27, 2008
    4,198
    3,261
    Gobowen near Oswestry !!
    Sorry, off topic !!
    FFS Joy go back to your other avotar ! :Blush::Blush::Blush:
  6. movan
    Dec 2, 2009
    13,624
    24,610
    Moving around
    oi. This is Gromett's post on his boiler, not my hairdresser....
    • Like Like x 1
  7. Diabalo
    Diabalo Funster
    Oct 14, 2007
    1,988
    387
    Rochester
    Who's your hairdresser? Stevie Wonder:Rofl1:
    • Like Like x 1
  8. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,346
    34,941
    PDFs of Operating & Installation instructions are available as links from Here. The former contains a troubleshooting guide.
    • Like Like x 1
  9. hilldweller
    Dec 5, 2008
    27,250
    26,251
    Macclesfield
    Amazing. Ours has taken to doing just that. No more than 3 "whoooooshes" but worrying even though it heated perfectly.
    So we went to Spinney Motorhomes, listed as Truma agents, "Nothing wrong Sir, so only £36". The service guy did wonder if it was poor 12V causing the bad ignition. He said there's no servicing done on them, more or less sealed 'till they fail.
    It's happened occasionally for months, I can't trace a pattern. I wonder if it's anything to do with varying autogas LPG mixes. I wonder if wind speed/direction is anything to do with it.
    If you find out I'd be very glad to hear the cause.
  10. haganap
    haganap Funster Life Member
    Dec 5, 2007
    11,154
    13,979
    Heavan
    Gromett
    Give truma a ring-
    There technical department is excellent. They can save you an absolute fortune. Mine is now fixed and working al for the princely sum of me being an idiot when I re plugged it after fitting my Solar Panel. Some engineers wanted to strip the whole thing out and take the boiler out :Eeek:
    A quick chat with the guys there and they had it sussed and working in mins.
    Twice this has happened last time it was hte regulator and again there was talk of taking boilers out, 40 secs on the phone to them and again the problem was solved..
    Here's there number, 01283 586020
  11. Gromett
    Gromett Funster
    Feb 27, 2011
    8,087
    14,689
    UK
    Thanks for that, I will be replacing the regulator today but I don't hold out much hope. The hob works exactly as before so I can't see it being gas starvation or similar but worth a try :thumb:
    It's not wind as it was doing it all day yesterday and it was sunny with no wind. I did think about the LPG mix as it started after I had filled up (I think)
    I have both of those already (loaded onto my playbook) As I installed it myself I needed the installation manual. I really could do with a service manual that has a clear schematic so I can understand how it works.
    My jobs for today once I get back to the workshop is, swap out the gaslow for a fresh propane bottle to see if it is the mix. If this doesn't work then I will try swapping the regulator out.
    If neither of these work I need to get it looked at I think. The ignition problem is bad enough that I am concerned...
    Thanks everyone.
  12. Gromett
    Gromett Funster
    Feb 27, 2011
    8,087
    14,689
    UK
    Thanks Haggers. If my two options above don't work I will give them a ring:thumb:
  13. JockandRita
    JockandRita Funster Life Member
    Aug 2, 2007
    5,856
    8,220
    Lincs/Cambs border
    Karl, I can concur with Paul, that the Truma Technical Dept are very good with help down the phone.
    Ours Truma C3402 stopped working shortly after we got the MH (third owners). The boiler failed to ignite although plenty of gas in tank.
    The advice was suspect sticky gas solenoids, possibly due to lack of use, (the two little square things sitting at 4 and 8 o'clock, close to the gas inlet connection). Gently tapping (emphasising "GENTLY") these solenoid valves with either a rubber mallet, or the wooden shaft of a ball pin hammer, whilst the boiler is trying to fire up, would probably release them. I did this and it has worked faultlessly ever since, however, it has always made that thumping noise on initial start up from cold, as does the Truma E2400 heater in the cab area.
    Good luck with it.
    Cheers,
    Jock.
  14. Terry
    Terry Funster
    Dec 27, 2007
    10,757
    6,253
    South yorks
    Hi Karl fist thing to do is listen to Haggers and ring TRUMA up :thumb:Save the trouble of swapping :Smile:
    Even if you need spares they are a lot cheaper than any dealers- dealer once quoted me £95 to supply a new Circuit board which truma quoted £35 for :Eeek: Cut a long story short my mate took a look at it and said it is either these or that,swapped a few things on it (mends tvs )and away it went :thumb:
    terry
  15. Gromett
    Gromett Funster
    Feb 27, 2011
    8,087
    14,689
    UK
    Refilled my LPG tank from a different source and tried it. Same problem
    Swapped it for a FloGas cylinder. same problem
    New Regulator. Same problem.
    Called Truma.
    Held the phone up while starting it up and he said it sounds like the flu is split.
    Take it out and check it :thumb:
    Busy day for me....
  16. GJH
    Aug 20, 2007
    27,346
    34,941
    Not quite what you want but there is a parts schematic Here. Right click and view image makes it clearer.
  17. Gromett
    Gromett Funster
    Feb 27, 2011
    8,087
    14,689
    UK
    Looked at it and it is a full days work. I didn't leave enough clearance for me to get behind it without stripping the wardrobe out...
    typical though, threaten the thing with a screwdriver and it has started behaving itself...:Rofl1::Rofl1:
    Got access to one of the workshop bays tomorrow so will strip it down anyway. I have some alumium tape designed for heating ducts so if there is a split I can do a bodge to tie me over till the new flu arrives...
  18. Gromett
    Gromett Funster
    Feb 27, 2011
    8,087
    14,689
    UK
    Todays the day. Spending all day stripping down the wardrobe/cupboard area so I can get to the boiler. Not looking forward to it but I am stuck on hookup until I can get it fixed...
  19. Terry
    Terry Funster
    Dec 27, 2007
    10,757
    6,253
    South yorks
    Good luck Gromett :Smile: That's exactly why I
    now tell self builder s to fit boiler and heaters last :BigGrin:
    Terry
  20. Gromett
    Gromett Funster
    Feb 27, 2011
    8,087
    14,689
    UK
    Bloody hell!!!!!
    Nothing wrong with the flu but I need a new O ring for it now...
    Can anyone recommend a supplier as my usual one can only supply the full flu kit not just the O ring:Doh:
