Truma 4E (1 Viewer)
Oct 29, 2008
5,068
5,949
West Yorkshire
PVC
since 2008
Ive has an issue where the truma blown air heating cuts out giving a flash code that translates to either the fan , temperature sensor or the PCB being faulty and causing the heater to shut down due to over heating. The van is brand new and its one this only happens when the heating is running full whack on blown air.
If the blown air tubes are restricted it can cause this type of fault, but they are all clear.
Ive had a truma trained technician take a quick look and he told me he had never seen insulation fitted to the hot air pipes where they leave the boiler and suggested that its possible that too much heat is being kept inside the boiler due to this insulation. The boiler is fitted under the half dinette seat so doesn't have a massive area to dissipate heat.
Ive removed the insulation from the tubes for the area inside the seat and have tested the boiler around 4 times today and the fault hasn't shown. I'm going to run it again tomorrow to be sure that its definitely cured.
Does anyone else here have a truma 4E Boiler, and are your blown air pipes insulated where they leave the truma?
jezport
Oct 29, 2008
5,068
5,949
West Yorkshire
PVC
since 2008
If this is a brand new van shouldn't the dealer be sorting it out for you?
5 hour drive away and they will fit one part and send me home to see how it goes.
Truma has technicians in my area so rater than waste 3 return trips using £200 of diesel im getting it sorted locally.
Sep 22, 2013
200
199
Halifax
Relay self-build
Trainee MH owner
No insulation on my blown air pipes from my Truma 4e and neither have I seen any on other installations!
Zigisla
2,580
3,106
Gosport, Hants
Sunlight A72
Getting better month by month.
My 6E is in a tiny cupboard under the wardrobe and does not have any insulation around the outlet pipes.
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
Not sure if you're aware that Truma are at Burton on Trent and you can call them for advice and/or book the van in and they'll fix it while u wait.
01283586020
jezport
Oct 29, 2008
5,068
5,949
West Yorkshire
PVC
since 2008
Im going to phone truma technical up tomorrow and ask them if the insulation should be used on the pipes close to the boiler.
Zigisla
2,580
3,106
Gosport, Hants
Sunlight A72
does the cupboard have air vents / grilles to let fresh air in?
No. it is just the bottom of the wardrobe. Cannot see very well, but it is jammed in there and there is just enough room for a bottle of red wine between the boiler and door(y)(y)
jezport
Oct 29, 2008
5,068
5,949
West Yorkshire
PVC
since 2008
I ran the boiler on no5 this morning from cold and it ran perfectly. So it seems that the insulation near the boiler was causing it to go to fault and shut down.
jezport
Oct 29, 2008
5,068
5,949
West Yorkshire
PVC
since 2008
I still have an intermittent fault on my Truma, I have it booked in at Truma tomorrow so will report back. Apparently the latest boilers have a memory of exactly what the unit was doing when a fault occurred and they have a diagnostic computer they can plug in.
jezport
Oct 29, 2008
5,068
5,949
West Yorkshire
PVC
since 2008
Arrived at Truma at 8.00am
Technician looked at boiler.
I was worried that the fault wouldn't show. But luckily it did, within 5 minutes.
They've sent me to their canteen while they look at it
Minxy
32,646
66,530
E Yorks
Carthago Compactline
... the suspense is killing me ...... o_O
sewinlynne2
180
218
Saron Dyfed
Elddis Riva GT Gold 175
since November 2016!!!
Could it possibly be a 'bodge' by either the factory or(more likely) the dealer? I would carefully check around the whole area where the 'insulation' had been put to see if there is any leakage of air from anywhere.
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
Hope they are paying for breakfast.
Minxy
32,646
66,530
E Yorks
My thoughts are that the insulation should have been removed when it was fitted ... but without seeing a photo I can't say for certain.
Vanman
1,665
3,916
Runcorn
Roadscout R PVC
March 2017
I think it's ... sausage eggs and beans! Maybe with toast ...
jezport
Oct 29, 2008
5,068
5,949
West Yorkshire
PVC
since 2008
The technician decided that the fault was most likely the PCB but it was a strange fault he hadn't seen before so decided the easiest option was a new unit.
Normally they exchange them for a refurbished unit of the same age. My Truma was almost new so he changed it for a brand spanking new one.
Sep 22, 2013
200
199
Halifax
Relay self-build
Trainee MH owner
Sounds like they have done the right thing and I hope that you find it now all works as it should.
Steve N Tracy
1,234
3,727
Southampton
4 Years
Our friends had exactly the same problem with their new Coachman at the Newbury show because they had no heating or water, I had a quick look, there are 2 PCB,s one you can see easy the other is nearly under the boiler they are joined by a ribbon cable, this had not been located properly pushed the connectors home properly and it gave no more issues.
jezport
Oct 29, 2008
5,068
5,949
West Yorkshire
PVC
since 2008
We didn't have no heat or water most the time it ran fine. But after leaving it on no 2 over night and turning up to 4 in the morning sometimes it would go to fault.
Jan 22, 2013
1,253
60,193
London SE
A class Adria vision I707
since 1971
My 4E is located under the wardrobe with little throughput ventilation,
so a quick drill with a rotary saw and a circular brown soffit vent to match the wood is all that's needed,
It might have been unessary but it give me peace of mind,
