Truck Sat Nav
Discussion in 'GPS Navigation' started by dotplus6, Jul 7, 2014.
  1. dotplus6
    dotplus6 Read Only Funster
    Oct 4, 2013
    183
    101
    N. Ireland
  2. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,968
    Happy with ours but not tried it in Europe
    • Like it Like it x 1
  3. dotplus6
    Oct 4, 2013
    183
    101
    N. Ireland
    Thanks Graham - Hubby thinks we should just use good old fashioned maps :) Maybe he's right - it would be good for the kids to utilise some map reading skills & probably wouldn't do us any harm either - we've become too dependant on technology.
  4. Southampton
    Southampton Funster Life Member
    Dec 16, 2011
    514
    300
    Hampshire
    Used mine down to Manilva (South Spain) and back earlier this year and did not have any problems. I inputted coordinates and it took me to the camp entrances every time. Very happy
  5. Linda and Steph
    Linda and Steph Funster
    Jun 18, 2008
    1,370
    1,412
    Lancaster
    Mine kept freezing and losing its settings, it's now in a box under the stairs. The sun-shade fits the new Caravan Club model Snooper that I bought at Stratford though.
  6. Brisey
    Brisey Funster Life Member
    Sep 4, 2007
    6,725
    8,552
    Tropical Bar,Benidorm.
    Mine got me from Newbury to Maidenhead, about 25 miles all along the M4. It then "encountered a criticl error" and froze. I tried to clear this error but the unit did absolutely nothing none of the applications would work. I managed to turn the thing off eventually, left it overnight and tried again the next day. It now tells me about the critical error and asks me if I want to return to factory settings, when I click on" yes" it does absolutely nothing, just brings up the critical error message again. In my opinion it is a load of rubbish.
    As they say "Good no cheap, cheap no good"
    • Like it Like it x 2
  7. dotsontour
    dotsontour Funster
    Nov 7, 2009
    102
    171
    I am now worried, down through France ,Spain ,Portugal and back no problem ran side by side with a garmin for two days just to check then put garmin back in its box to be used if we do get into trouble.
    Perhaps I have been lucky ( it makes a change )
    Regards Dave
  8. Forestboy
    Forestboy Funster Life Member
    Jul 31, 2007
    5,124
    8,355
    Forest of Dean
    Brian
    I had one and had exactly the same problem. They sent me a new card which worked for a few days then same problem again. Then they sent me a completely new unit which had the same problem straight out of the box. By then I'd had enough and got a refund and postage costs plus 6 emails begging me not to give them negative feedback.
    As you say total rubbish stick to my Garmins nothing else gets close for me.
  9. gloworm
    gloworm Funster
    Dec 30, 2008
    916
    1,731
    Cheshire
    Brian there is a reset button on the back, you need to insert something with a point, if you already tried it please disreguard, but good luck with it,
    Eric
  10. lunarman
    lunarman Funster Life Member
    Sep 23, 2008
    1,481
    888
    South Glos
    Just came back from 5 weeks in France sat nav worked well never lead us astray once.
  11. ukbill
    ukbill Funster
    Nov 3, 2011
    4,969
    4,899
    benidorm
    brain like eric said use the reset at the back mine has now took me all over the place with no problems france,germany,italy,austria,czech,poland,spain,portugal and everywhere in the uk i been with no problems at all (y)
  12. Brisey
    Sep 4, 2007
    6,725
    8,552
    Thanks for your replies guys. I plugged the Sat Nav in and let it charge up while we went shopping. On our return I turned it on and got the same "critical error" message on the screen. None of the Apps worked, I just got a beep from the Navigation button. I then tried to reset back to factory default, it told me I would loose all of my POI's etc. I stuck a pin in the reset port and lo and behold something different came up. The error has now gone from "critical" to "fatal" and it is now asking me if I want to return to factory default settings again. I am now about to carry out a fine tuning adjustment using a rusty tent peg and a 3 pound club hammer. If that fails it's going back to meet its makers.
    Doctor Brisey, Satellite Navigation System Surgeon.
  13. WynandJean
    WynandJean Funster
    Mar 23, 2010
    2,620
    1,470
    West Midlands
    Yes, still happy with ours. Taken us as far south as south of France and north to Scotland. No probs
    Wyn
  14. lunarman
    Sep 23, 2008
    1,481
    888
    South Glos
    Brian,
    I believe this error may be caused if the unit switches itself off when the battery is depleted. Plug it into a power source and when it asks you to return to factory settings click "no". It should start up if it does shut it down correctly so that it does a proper controlled shut down. Then all should be well (hopefully)
    John
  15. cruiser
    cruiser Funster Life Member
    Sep 12, 2012
    3,020
    2,863
    northampton
    when you lot find all the props.and how to fix them.then I will buy one.thanks in advance.
  16. Tootles
    Tootles Funster
    Sep 14, 2013
    9,242
    33,103
    Lancaster
    Love ours. By my own fault, I had not set the weight limit, and, (as it turned out), the default is four tons. Approaching a railway bridge on a country road heading towards Brampton, Cumbria, on a road I know well, when it screamed out 'You are approaching a bridge with a weight limit of 3.5 tons'. Big deal, (thought I), well under that......But then Johnny sat nav would have nothing to do with me unless I took the alternate route, (which we didn't).
    It sulked for a whole day, until I set the correct weight into it. So, it works!
  17. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,929
    3,394
    Eastbourne East Sussex
    Mine is currently in the 'fatal error' phase. Will keep trying for a bit. It worked fine down to central France then threw a wobbly for no apparent reason.
    It was very cheap, so if it works you're lucky and if it doesn't, no great loss.
    I have two other satnavs in the MH and if all else fails my phone has quite a good satnav app on it.
  18. Southampton
    Dec 16, 2011
    514
    300
    Hampshire
    It looks like there is a fairly high failure rate. I will have to update my tom tom and carry that in reserve and see how long mine lasts, although to date it has been spot on and not a hint of a problem. If it fails then I will try Doctor Brisey's remedy !
  19. ukbill
    ukbill Funster
    Nov 3, 2011
    4,969
    4,899
    benidorm
    dont matter if ya sat nav is good or bad always carry maps best way there is
    • Like it Like it x 3
  20. Bailey58
    Bailey58 Funster Life Member
    Jun 23, 2010
    6,655
    10,333
    Norfolk and Toftir.
    Mine's only been used twice so far, going to the campsite alongside Nostell Priory recently it did warn me the route would take me along banned roads, or whatever the terminology. It was the long approach off the the A638 that was, or would have been a problem with a lorry. First trip took me a better route from the Garmin. So far so good.
Similar Threads
  1. jessthedog
    17
    296
  2. scotty1
    5
    305
  3. scotty1
    13
    560
  4. laurieash
    9
    497
  5. Madmag
    15
    675
