Trouble with my Caver Trumatic sb1800
Discussion in 'Tech/Mech General' started by Leaveyfreya, Oct 18, 2009.
  1. Leaveyfreya
    Leaveyfreya Read Only Funster
    Sep 20, 2009
    21
    Cumbria
    Dont know if this is the right area to ask, but I will try! I am sure someone will list it right if I am wrong.
    Our carver Trumatic sb1800 heater is working fine but seems to click randomley as though it is trying to ignite, even though it is working, sometimes only six clicks but other times it could give up to 50 clicks then stops any ideas to the fault? :Doh:
    Thanking you in advance
  2. vindiboy
    vindiboy Funster
    May 22, 2008
    488
    If you are parked too close to a wall or something the heater can do that, something to do with exhaust gas being restricted ??????????
  3. Leaveyfreya
    Sep 20, 2009
    21
    Cumbria
    Thanks for that, its not near a wall or anything like, but like you said maybe the exhaust is restricted in some way.
  4. Spacerunner
    Spacerunner Read Only Funster
    Apr 7, 2008
    609
    195
    Hampshire
    Are you sure its not just the sound of the metal casing expanding with the heat?
  5. Leaveyfreya
    Sep 20, 2009
    21
    Cumbria
    Hi thanks for response defo sounds like the starter i liken it to my gas fire that had a piatzo starter. knowing this is not piatzo.
    I think the spelling of piatzo is wrong but you will get the jist
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,112
    17,781
    YO11 2BD
    are you 100% sure it is still burning when its clicking.
    the heat exchanger will still chuck out heat even when the flames gone out.
    could be an intermittant flame fault and the ignitor is actually trying to re-light it.
    or it could be the flame failure sensor at fault.
  7. metz
    metz Read Only Funster
    Nov 15, 2008
    9
    Hi, I would recommend getting the heater serviced, if the ignitor is operating once lit could indicate several faults, could be a problem with the valve, or the burner, the ignitor itself could be faulty, sparking to earth witch is a HT lead fault, exhaust blocked,could even be a gas supply problem.
