Trigano Tribute 06
Discussion in 'Motorhome Chat' started by Roachy72, Jul 25, 2015.
  1. Roachy72
    Roachy72 Read Only Funster
    Sep 22, 2014
    22
    4
    Woodchurch Kent
    Need some help, can anyone explain how I get hot water? I have followed the instructions in the manual but mo hot water? It's an 06 model, if anyone can help it would be very much appreciated
  2. wingman
    wingman Funster
    Feb 10, 2013
    1,007
    2,548
    Romford, Essex
    Can you give us a bit more info @Roachy72
    Like.......
    • Do you have cold water flowing from taps?
    • Are you sure you don't have the 'dump' valve open?
    • Is the water heater filling ok?
    • What sort/make of system do you have?
    Have you just acquired the van? Can the previous owner or dealership help?
    Normally, it will be something simple causing the problem. Rest assured, Funsters will sort it for you!
    James
    • Like Like x 1
  3. Margaritaman
    Margaritaman Funster
    Oct 27, 2013
    95
    114
    East Yorkshire
    Have you removed the cowl covering the gas boiler flue on the side of your Tribby?
    If there is a window directly above the flue check it is closed. Boiler will not light if the window is open to stop fumes entering the vehicle. There may be a safety switch fitted inside the window frame which will activate if the window is open.
    Chris
    • Like Like x 1
  4. Roachy72
    Sep 22, 2014
    22
    4
    Woodchurch Kent
    Sucesss at last for what ever reason the boiler would not ignite, so I tried various things, I switched the pump of and the boiler ignited. Many thanks for help, a very happy man.
    • Like Like x 1
  5. Margaritaman
    Oct 27, 2013
    95
    114
    East Yorkshire
    @Roachy72 Glad you're sorted. As well as this site you may find the Tribute owners site www.tribby.co.uk/forum has a lot of helpful information about your 06 Trigano Tribute.
    Chris
    • Like Like x 1
  6. Roachy72
    Sep 22, 2014
    22
    4
    Woodchurch Kent
    Cheers Chris great site, very useful.
    • Like Like x 1
