Travelling with hot water on (1 Viewer)
Apr 17, 2017
1,109
3,584
Ferring
Autotrail Cheyenne 840
Since 2017
Is this a no no or is it ok to drive with the hot water operating on gas.
Does anyone do it ?
Dec 30, 2008
1,106
2,126
Cheshire
since Dec 2008 after 10 years caravanning
Never tried it, but as you have to remove vent cover i think the wind would blow the flame out or blow fumes into m/home.
Eric
Badknee
7,407
412,448
notloB
Vantage Neo
Living the dream.
We drive with the central heating on gas to keep the hab area warm. (y)
May 28, 2016
118
99
stoke on trent
Hi top
since 2000
I would think very risky what would be your chances of getting out in one piece if you had a collision and had a fire
moulin 87
688
811
Limousin, France
Dethleffs Espirit T7150
Newbie
Later models have a 'crash' sensor which automatically closes off the gas inlet...
scotjimland
2,298
9,951
A Woosh bang
Depends on model .. I assume it's a Truma ?
Is it possible to operate a Truma heater even whilst driving?
Yes. With Combi and Trumatic E heaters, the heating function can be used without a problem whilst driving.
In the case of Truma S / Trumatic S heaters, however, the heating function can only be used together with a cowl top, which must be installed freely in the air flow. Truma recommends cowl top T3 or T2. Otherwise, the flame may burn back and cause damage to the heater.
Additionally, the cowl top must protrude at least 10 cm beyond any additional roof accessories (roof boxes, ski racks, luggage racks, etc.) so that the heater can function without problems.
You can find out more about safe heating whilst on the move Link Removed.
Link Removed
In winter we travel with it on, I have Gaslow R67 bottles fitted which have a safety shut off if a hose is ruptured..
CWH
5,140
247,350
UK
WildAx PVC
From November 2013
The van-I-sold-last-October (2014 model) automatically switched off the gas as soon as the engine ignition was turned on. A good safety feature I thought.
Rockcrawler
Apr 17, 2017
1,109
3,584
Ferring
Since 2017
I have a trumatic C6002 EH and as far as I can see there is no removable cowl.
I'm sure it will be ok then
Thank you for your replies
Lenny HB
53,399
149,821
On the coast in West Sussex
Hymer B678 DL
The C6002 is fan flued and can be used on the move providing you have the Secumotion regulator which has a crash sensor and either the pigtails with safety rupture valve or bottles with built in anti rupture valves. Otherwise please don't do it for your own & others safety.
Jaws
23,834
72,435
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
The heating system is designed to be used while on the move, and if you read the full manual there is absolutely no suggestion it is not safe to have the water heater on either. ( This for the Truma systems.. canna speak for the Carver or its later incarnation )
May 8, 2016
1,685
80,660
silver coast, portugal
C Class: Low profile
Boatie for 20 years
I take the points made, and I can only quote from the Chausson manual here:
The motorhome is further prepared for use by positioning the
gas bottles (PROPANE only) in an externally-accessed watertight
locker. Gas bottles must be turned off when vehicle is in motion.
When driving, gas cylinders must be closed.
Pictograms are placed in the appropriate location to
remind you of this.
- It is forbidden to run the refrigerator on gas when travelling. If there should be a fire following an accident this could cause an
explosion.
All appliances operating on gas must not be used unless
the vehicle is stopped. (parked vehicle).
People will obviously do as they please, but that is what it says in the manual which reassures me regarding safety, my fridge works fine off the battery, and it only takes 15-20 minutes to get as much hot water as we need once we have stopped (and turned the gas on).
Copy attached
  • MANUEL-Chausson-2014-Anglais.pdf
Jaws
23,834
72,435
Thetford Norfolk
C class, Chieftain
Copy attached
Well given they say gas bottles should be turned off the rest seems completely redundant information !
Have never run with gas turned off, have used all appliances when moving.. But I guess having superior motorhomes built to do the job and not a Chausson must make a difference ;)
( and I am just leg pulling here.. before someone gets all shirty and defensive about this or that make of van ! )
moulin 87
688
811
Limousin, France
Newbie
Copy attached
But does your Chausson have the 'crash sensor system' ?
May 8, 2016
1,685
80,660
Boatie for 20 years
Joke taken in good spirit mate. Chausson use the same heaters and fridges as everyone else, so perhaps those of us with more modern vehicles are subject to more 'elf and safety warnings (just a dig)
The quotes were taken from various parts of the manual I uploaded, different references on different pages. Probably is just 'elf and safety guff, but I don't need the gas on whilst travelling, so rude to just ignore it.
Yes, it does have the collision detection system, it is just over 12 months old from new
The way I see it, if you have to turn gas off for ferries and whilst refuelling, why bother turning it on until you park up? Especially as my fridge works great on battery, the hab heater is diesel and the water heater can scald a hot thing in minutes (perhaps because they're new?)
Now I know someone is going to say they never turn off their gas on a ferry or in the channel tunnel, but I'll leave everyone else to tear them to shreds as I am being dragged off punishment shopping (forgot anniversary yesterday) :(
CWH
5,140
247,350
UK
WildAx PVC
From November 2013
Apparently European safety regs apply for gas heating while travelling for all vehicles 2007 and later.
This is the Truma thingy, looks very Heath Robinson but obviously works & meets all regs - simple is best!!!
The Dotties
1,872
4,022
Gloucester
In between
Ex Newbie
My AT Dakota will not allow anything but battery to fridge with engine running.
May 8, 2016
1,685
80,660
Boatie for 20 years
@CWH
Well, that is a reassurance. I suspect the Chausson manual was just over egging the 'elf and safety issues.
suavecarve
7,542
38,935
Surrey/Hants
Rollerteam 685
July 09
Good work on forgetting the anniversary. 35 man points and only punishment shopping. Good effort.
I have to forget an anniversary and 50th birthday this month. Wish me luck
(I don't get punishment shopping by permanently wearing outrageous clothing which she wouldn't be seen with me wearing) I don't know if she has cottoned on to this but I have awarded myself 43 man points for it !
D
Deleted member 29692
British vans tend to be like that. Some daft NCC guideline they all follow
Continental ones never are; everything works all the time.
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
Sometimes run with the heating/water heating on gas. Very useful in the winter to avoid the auto dump valve dropping the water. We have secumotion on the gas.
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
When travelling in the Alps in winter, it is essential to have the heating and hot water on otherwise the system will freeze.
Our system is diesel fired. It gets switched on when we leave home and only gets switched off again at the end of our holiday.
Aug 18, 2014
23,764
133,448
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Eric
No they are balanced flue so the air is drawn in from outside through one part of the outer vent & fumes are expelled through another part.
