Travelling in the cold (1 Viewer)
Badboo
89
11
Northern Portugal
McLouis Mc2 72 motor home
This our first!!
We are hoping to travel to Salzberg over Christmas. However I'm a little concerned about using the motorhome in freezing temperatures.
Can anyone detail what precautions we should take in these conditions.eg does the heater need to be running all the time, even if we are off sightseeing during the day?
Thanks in advance.
Jul 7, 2016
238
125
Powys, UK
hymer b584
Im a newgie
My heating went a bit squiffy last night, in heavy frost, the fan kept going on and off every 2seconds and the red light started flashing, it seems OK today restarted it after mid day? What's that all about. ?
CWH
5,145
247,428
UK
WildAx PVC
From November 2013
Universal Fixing Procedure Mark I
- thump it
Universal Fixing Procedure Mark II
- switch it off at the mains, count to 10, switch back on again
Vanman
1,665
3,916
Runcorn
Roadscout R PVC
March 2017
- thump it
Heavens - that's pre-historic :xdoh:
Everyone knows you reboot first these days (and then thump it if it isn't fixed) :xThumb:
TerryL
6,184
8,186
North East
Low Profile
BUT SERIOUSLY
Are you using butane? Or if refillable is there any chance you've got some butane in your gas bottles/tank? What I mean is, have you ever refilled with butane and not completely purged the bottle/tank? Butane won't gas at temps below zero and that sounds to me like a gas supply problem - it's okay when the temp gets up a bit.
CWH
5,145
247,428
UK
WildAx PVC
From November 2013
Aw c'mon, read carefully - MARK I & II, not STEP 1 & 2! :LOL:
12,264
45,049
Norfolk
Nearly Tugging
Since 2004
For anti freeze strength you can get a small hydrometer specifically for the purpose from motor accessory shops. It's a diddy little thing around 3" long that indicates degs of frost protection.
855
4,812
cardiff
Frankia 7900 Platin plus
since 2010
'm'off to St Anton - will be there end of next week. Forecast -39'c!! That'll test the truck.:cold:
Badboo
Badboo
89
11
Northern Portugal
This our first!!
Forecast -39'c!!
Now I feel like a complete wuss!!
Can anyone tell the purpose of the two vents, either side the base of the door to the cabin? I can't find any mention of them in the owners manual and they let in a lot of cold air.
Theonlysue
6,104
7,383
Essex
As Executive 50th an
Not long enough!
Might be worth carrying extra container of water in the van, in case any places you stop at en route have frozen taps.
Also how best to insulate your van even more.
Shoving a blanket in the footwell.
Can you curtain off the front cab area Al together if you don't need it?
Ensure curtains are on the floor stopping any drafts.
23,779
133,598
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Just blank them off with tape .Many do Also have a quick look underneath on sill inside to see whether there are vents there & if so tape them off.
TerryL
6,184
8,186
North East
Low Profile
Yep - they're specially designed by the manufacturer to introduce icy cold drafts into your motorhome! (Actually I believe they're meant to provide ventilation on the cab-only versions of the Ducato chassis).
A few strips of duct tape over the vents will make an enormous difference to the cab temperature. We did it years ago, no more drafts.
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
The thick sox you need to protect feet from the icy draughts coming from the footwell !
