"Traveller 2500H" Generator problem (1 Viewer)
Swifty_Morgan
19
3
South Staffs
Eh?
several years
To cut a long story short, my internal Battery charger went 'Pfft' and I had no end of fun sorting out the 12v electrics (at a time when I was not very well).
I bought and fitted a new charger (e-bay) and it also went 'Pfft'.
I sent it back under the warranty (bless 'em) and discovered that the AC input voltage was over 270v (at which point the charger goes 'Pfft').
So I made a filter.
I've had the whole 'van and genny serviced this year and I measured the generator output voltage: 276v. This is not good. :cry:
What's worse is the '12v dc' output is actually 25v !.
Has anyone got any real info on the Electrolux (Dometic) "Traveller 2500H" petrol-driven generator please ?
What is it that regulates the output ?
And where can I get spares ?
Many thanks
Dave
:help:
scotjimland
2,230
9,711
A Woosh bang
So I made a filter.
[HI]I've had the whole 'van and genny serviced this year [/HI]and I measured the generator output voltage: 276v. This is not good. :cry:
Many thanks
Dave
:help:
have you spoken to the company that 'serviced' it, was it ok prior or is that an unknown. ?
from what you say it looks like the voltage regulator (no surprise there) has gone awol.
Speak to Dometic and ask where your nearest service agent is, then call and ask for advice.. If it is the regulator it will be fairly expensive.. sorry can't help more..
S
Swifty_Morgan
19
3
South Staffs
Eh?
several years
The firm that did the MH service conceded that they were a touch limited with these generators. I don't have a problem with that.
I spoke to the firm who I believe is my nearest service agent. Whilst polite and generally helpful, I got the impression that there was some information missing. (But I guess makers of these gadgets don't document Everything, do they.)
Regulators come in assorted types & sizes. I've had some useful griff from Phil J., (for which many thanks, BTW). I'll study this and see whats to do.
But it looks like a pricey repair, win loose or draw !.
Hey Ho. . . .
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
sounds like it may be over revving slightly as its normally the speed of the engine that controls the output voltage unless its got an inverter like the small suitcase hondas etc.
S
Swifty_Morgan
19
3
South Staffs
Eh?
several years
At present I have no means of checking speed (I suspect it should be 3000 rpm). But the drawing I have been sent should help when I get to study the problem further (I'm having trouble with the idea of a capacitor to control output voltage).
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
hi i wouldn't think that a capacitor would control the output voltage it would just catch the spikes and smooth the output.
the info i got from the dometic site states 230volts +/- 10% so anywhere between 207 and 253 volts would be a normal output voltage.
the other thing of concern would be if the frequency of the output has altered from 50hz but without access to an oscilloscope you would never know.
S
Swifty_Morgan
19
3
South Staffs
Eh?
several years
The windings transformer has a capacitor on one of the three windings, which leads me to suspect that the unit features elements of a "Constant Voltage" system (Advance used to make them, amongst others).
milltech
Great Malvern
Very late in the day on this thread! I have a Traveller Genny and my local garage say the butterfly on the carb is jammed open and they don't know where to access a new one. Have sent a pm to Swifty but any additional information would be most gratefully received.
JockandRita
11,443
149,716
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Any Honda genny spares outlet. I am advised that the engine is a GX160
My butterfly valve was gummed up until I recently used carb cleaner on both my Traveller genny carburetor, and that of a fellow MH owner. Both our gennies start first time now.
HTH,
Jock.
kawasaki
iveco
hi , I have a T2500HG generater under my van , ex Salvation Army soup kitchen. But the lpg got disconnected from the generater and I have know idea where it connects on the landi Renzo vapouriser, it's a 2002 model,can't seem to get any info,can any one help.
JockandRita
11,443
149,716
Lincs/Cambs border
N+B Flair 8000i
Sorry, I'm unable to help as ours wasn't converted to gas.
Since my post above back.in August 2013, I have replaced the carburettor and fuel lines, which the current owner now has the benefit of.
Cheers,
Jock. :)
Jun 10, 2010
8,473
20,117
Shrewsbury (sometimes)
N&B Clou Liner MAN
I think I might have a similar model also lpg converted, Mine has Beam 52 that I think is a volumiser not a vaporiser. Its fairly obvious where it connects. Mine is a bit of a work in progress also, its running again and we have 12 volts but Ive had to have a new rotor ( easy) but also had to have the starter motor refurbished - basically remanufactured the middle bit and brush carrier at £400.
Steve53D
Birmingham, UK
Just starting
I have recently purchased a mirage 5000 2001 with a dometic generator fuelled by LPG but unable to start.
Engine turns but dont fire.
Any ideas please ??
JockandRita
11,443
149,716
Lincs/Cambs border
N+B Flair 8000i
jongood may be able to help, having recently acquired a lpg genny himself, with problems starting it.
Cheers,
Jock. :)
Steve53D
Birmingham, UK
Just starting
I'm not sure if gas is going to it because I'm unable to open the casing at the moment which dont help.
stewartwebr
1,102
3,405
Edinburgh
Morelo Empire Liner
36 years and 16 motorhomes
It is common for the capacitor/condenser to fail. They can be replaced for £60 from Dometic or the same spec from Amazon for around £9. The LPG solenoid is supplied from the 12Volt starter battery on initial start up when the green button is held in. Once the machine has started the 12 volts from the generator supplies the solenoid to hold it open and keep it supplied. The white button acts as a choke and opens the vapo riser further, you should hear it click as you press the white choke button. Secret with these units is not to flood them on start up. Press the green to start it then press the choke for a blip 2 or 3 times and it should start. If the capacitor has failed it should start when green button is pressed but shall shutdown as soon as you remove your finger from the green button as the fuel solenoid closes due to no voltage to hold it open.
Dec 12, 2010
5,396
21,440
Cumbria
since 2011
Any ideas please ??
As a quick check, try spraying some easy start or carburetor cleaner into the intake, after removing the filter, this will tell you if it's a fuel or spark issue ?
