traumatic c (1 Viewer)
Darren
192
39
Canterbury Kent
Adria Izola
im in Spain at the moment. I have just switched to a Spanish butane bottle, the fridge and cooker works on it but the heating will not fire up on it. When I put my calor propane bottle back on it fires up straight away. Anyone had this problem?
BONZO
436
310
Rotherham
Kon tiki 30ft
Could it be the presher turn others off and try heating then put others on one by one .
Darren
Darren
192
39
Canterbury Kent
Adria Izola
Still the same even putting one piece of equipment on one at a time. The boiler will not fire up on Spanish gas
Lenny HB
53,421
149,942
On the coast in West Sussex
Hymer B678 DL
Common problem with Combi's, butane can not deliver a high enough flow rate, problem is worse the colder it is, as then the butane can't gas off fast enough.
scotjimland
2,319
10,000
A Woosh bang
What regulator(s) are you using ?
A bulkhead 30mb or top of bottle regulators ?
Darren
Darren
192
39
Canterbury Kent
Adria Izola
I have the jumbo adaptor on the bottle which then goes to the bulk head regulator
scotjimland
2,319
10,000
A Woosh bang
so should be ok..
what is the weather like.. is it cold at night ?
It may be too cold for Butane to work properly.. If below 6c it stops gassing ..
Minxy
32,649
66,535
E Yorks
Carthago Compactline
I suspect its because it's butane rather than propane - whilst your other appliances work they won't have such a high demand for gas as the heating will so couple that with it being cool, hence why you want the heating on, then butane will not gas so well as when it's warm ... when you DON'T need the heating on.:doh:
Lenny HB
53,421
149,942
Hymer B678 DL
so should be ok..
Just to be perdantic butane stopps gasing at 0c, agree it is useless at 6c not much cop until above 10c.:)
scotjimland
2,319
10,000
A Woosh bang
in pedantic mode.. Boiling point of Butane is -1 °C but who cares..
my post wasn't a chemistry lesson, but just good old fashioned practical advice.. as you said.. at 6c Butane is all but useless
Darren
Darren
192
39
Canterbury Kent
Adria Izola
I have tried it in the middle of the day when it's warm and still no lighting. This afternoon I am going to try and swap it for a propane one. Maybe these combo boilers do not like butane?
scotjimland
2,319
10,000
A Woosh bang
provided it isn't too cold.. it shouldn't be a problem on Butane
.. Truma information says it should work equally well on either gas
have you tried another bottle of Butane ? could you borrow one just to test ?
Darren
Darren
192
39
Canterbury Kent
Adria Izola
I'm going to change it for a propane bottle The nights have started to really drop in temperature so I think a propane bottle is the way to go till I get home.
scotjimland
2,319
10,000
A Woosh bang
good plan..
even when it gets warmer during the day, the Butane in the bottle will take many hours to reach a decent temperature and gassing point.. if it ever does.. unless you warm it on the cooker (joke)
I haven't used Butane in donkeys years..
Darren
Darren
192
39
Canterbury Kent
Adria Izola
Update
Have exchanged the orange butane bottle for an orange propano bottle. The Boiler fired up straight away and has been fine. Maybe these combo boilers don't like butane gas
Minxy
32,649
66,535
E Yorks
Looks like it was too 'cool' for the butane to gas properly, at least you can keep warm now!
JockandRita
11,462
150,129
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
17 degrees today. Will investigate further when home
TBH Darren, no need to waste your time investigating, as the answers are above, ie, the butane gas was at too low a temperature to gas off, regardless of what the ambient temperature is.
Changing over to propane solved the problem, as the liquid inside the cylinder was able to gass off at the lowere temperature. Like @scotjimland, I haven't used butane since my early caravanning days.......................when I found out why my heating wouldn't operate in March, with a full cylinder of.................... wait fot it.................butane. :LOL:
Cheers,
Jock. :)
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Butane can really catch you out. It may be that the air temperature is high enough for it to boil off - but as it does so it cools itself down. The more it boils (which happens when you draw off more gas) the lower the temperature of the bottle. You can often see a ring of frost on a gas bottle when in theory day is warm enough to use butane.
Darren
Darren
192
39
Canterbury Kent
Adria Izola
Cheers,
Jock. :)
Ok will stick to propane out here. Just wondering why at midday at 17 degrees the butane still would not gas off?
