Traumatic C
Discussion in 'Heating and Air-Conditioning' started by Pow210, Nov 17, 2015.
  1. Pow210
    Pow210 Read Only Funster
    Oct 20, 2015
    7
    Drumnadrochit
    The heater fires up fine on gas then after 5/10 mins starts to cut out and in every 15 seconds, then red light starts flashing. Any suggestions would be much
    appreciated.
    Stewart (pow210)
  2. WillH
    WillH Funster
    Feb 9, 2008
    1,719
    1,427
    SW Scotland
    Could well be gas supply problems, choked regulator?
  3. Badknee
    Badknee Funster
    Aug 25, 2014
    3,732
    16,411
    notloB
    Yes or a dodgy thermostat
  4. Pow210
    Oct 20, 2015
    7
    Drumnadrochit
  5. Pow210
    Oct 20, 2015
    7
    Drumnadrochit
    Cooker and fridge working fine on gas
  6. WillH
    WillH Funster
    Feb 9, 2008
    1,719
    1,427
    SW Scotland
    They use a lot less gas than the heater so a choked regulator may still be able to supply them . How long is it before you can fire up the heater again after a failure?
  7. Pow210
    Oct 20, 2015
    7
    Drumnadrochit
    Hi I usually leave it for 30 mins before trying again and the same thing happens
  8. Pow210
    Oct 20, 2015
    7
    Drumnadrochit
    The gas is LPG
  9. Pow210
    Oct 20, 2015
    7
    Drumnadrochit
    Thanks I'll check the regulater.
  10. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,275
    7,939
    West Norfolk
    Wind?
    I know they don't normally get affected bit it is blustery out tonight.
  11. WillH
    WillH Funster
    Feb 9, 2008
    1,719
    1,427
    SW Scotland
    How did you get on last night or did you freeze?
  12. pseward152
    pseward152 Funster
    Jun 9, 2014
    6
    4
    essex
    I had same problem this was solved by changing the gas bottle apparently the heating demands more gas than was being delivered by my very low gas bottle
  13. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,037
    6,047
    West Sussex
    Where& when did you last fill up with LPG? If outside the UK you probably had a butane & propane mix, the propane will gas of first leaving butane. Combi's don't like butane can't get enough gas flow also if temp below 10 deg no chance with a Conmbi on butane.
    • Like Like x 1
  14. travelling wilbury
    travelling wilbury Funster
    Mar 27, 2016
    93
    37
    somerset
    i assume the OP got this resolved, its always nice to get these threads nicely tied up with a 'this fixed it' resolution.....like a nice help desk system....., lol....
    from scanning a few similar threads, it looks like the flashing red light on Truma devices means poor 12v supply, while continuous red light is usually a gas issue.....
    • Like Like x 1
  15. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,037
    6,047
    West Sussex
    If you have a CP plus controller you get an error code and not all of them are listed in the instructions, not very helpful.
  16. Cleve
    Cleve Funster
    Aug 27, 2015
    346
    552
    North West Europe
    At the risk of making myself unpopular - did you remove the flue cover from the outsider wall of your motorhome. I am sure you would have but just in case. If left on it will work a while then die
  17. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,037
    6,047
    West Sussex
    Combi's don't have a flue cover.
  18. Cleve
    Cleve Funster
    Aug 27, 2015
    346
    552
    North West Europe
    Ah, I stand corrected, still back in the Stone Age here! When I retire and update a new world awaits. Thank you
    • Funny Funny x 1
