Trauma water heater
Discussion in 'Tech/Mech General' started by Wildbill, Aug 23, 2016.
  1. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,175
    12,520
    goole
    Jus starting to investagat why the boiler hasent Ben working for the last three years
    Removed the cover from the boiler bord
    Fund this
    I have soldered the offending Wier's
    Put the wiring block in and hay presto it all lights up
    Bill
    • Like Like x 1
  2. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,175
    12,520
    goole
    OK my water heater panal switch lights up but then the read a green lights come straight on
    Any one our thee with knowledge of any thing that causing this fault
    Bill
  3. Bart
    Bart Funster
    Jun 4, 2016
    1,623
    472
    N.Ireland
    I have noticed with ours that if you set the dial to say 60 degrees for hot water ( on gas ) then turn on the Truma heater at the control panel I get the following :
    Green light , orange light & the RED light .
    BUT if I FIRST set the heating control knob in the OFF position then turn on the Truma heater at the CONTROL PANEL . Then select say 60 degrees it works ok with just the green and orange lighting up ok.
    I have no idea why mine does that .
    Have you tried Turing it on differently ..gentle like a woman :)
  4. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,175
    12,520
    goole
    I have the touch of a midwife delivering a baby rink all
  5. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,175
    12,520
    goole
    I have taken a pick of the bord thee is a round thing it looks like the botum of it has blown out
    Extruding the rubber seal
    Its the one on the piss
  6. Newfie
    Newfie Funster
    Jul 5, 2016
    75
    42
    Essex
    It's a capacitor that's blown, could be the electrolyte dried out & it shorted out or something else blew it. Tried searching Truma site for the board number but nothing found, I guess it's an old Truma heater.
  7. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,175
    12,520
    goole
    Yes it is fund someone who reconditions them for £50 so sending it off tomorow
    Bill
  8. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,175
    12,520
    goole
    Can the capacitor be sourced or wil another make do the job
    Bil
  9. Newfie
    Newfie Funster
    Jul 5, 2016
    75
    42
    Essex
    I guess they are still available, but it could be something else blowing it.
    I can't tell what it does as I don't have a circuit diagram.
    £50 sounds a good deal. Unless it is just the capacitor at fault a few pence.
  10. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,175
    12,520
    goole
    I am while I have the boiler out outing a heat exchanger could in the boiler.
    Will heat from the engine of the heater system that way its after the thermostat
    Bill
    It will save lods of gas
    bill
