Trauma Heating Burning Smell
Discussion in 'Heating and Air-Conditioning' started by weekenders, Dec 13, 2012.
  1. weekenders
    weekenders Funster Life Member
    Apr 30, 2008
    2,218
    1,283
    Leicestershire
    Wondered if anyone could give us advise, we have a Hymer 584, 1999 model.
    Last weekend we put the water on to heat up and after about 25-30 mins there was a funny smell coming from the water boiler in the wardrobe, bit of a burning smell, the water does get hot but unsure what the smell could be.
    The Traumatic C contol switch can be set to up (water & heating) or down (heating only), switch to the left is 60deg switch right 40deg, there is also a temp dial 5-30
    Could the thermostat have gone??
    Any help would be much appreciated:help:
  2. ubuntu1
    ubuntu1 Read Only Funster
    Feb 13, 2008
    155
    44
    Derbyshire
    Truma boiler
    It could be a number of things and it needs invetigating. It could simply be dust getting hot which does smell. It could be failed overheat sensors or something more serious.
    There are too many maybe's to give you a proper answer.
  3. driving
    driving Read Only Funster
    Mar 7, 2012
    97
    100
    doncaster southyorkshire
    truma
    hi bob and val
    if you can smell burning turn on taps, if it spits water out its air in the system ours does that.
    hope it helps
    mark
    • Like it Like it x 1
  4. canopus
    canopus Funster Life Member
    Nov 27, 2010
    3,271
    3,635
    Lincolnshire
    Val
    Sounds like your Truma is really giving you a trauma :Rofl1::Rofl1::Rofl1:
    Are you certain that the dump valve on the Truma hasn't dropped the water contents out due to the very cold weather of late?
  5. weekenders
    Apr 30, 2008
    2,218
    1,283
    Leicestershire
    Thanks Mark
    The burning smell is coming from the water tank in the bottom of the wardrobe, not the taps, it was spitting the water out at first just thought the water tank was empty, (it was a little low), we have now filled the water tank and it still smells!!
  6. weekenders
    Apr 30, 2008
    2,218
    1,283
    Leicestershire
    Are you certain that the dump valve on the Truma hasn't dropped the water contents out due to the very cold weather of late?[/QUOTE]
    Rob has a pegg on the dump valve as when we first got camper it dumped all the water (not icy)??
  7. MikeandCarolyn
    MikeandCarolyn Read Only Funster
    Mar 18, 2008
    2,171
    1,463
    Worle,North Somerset
    3 yrs ago we noticed the same thing-and worried about it.I had it all looked at, was told no problems that they could find.It still happened-now we lay in bed,smell the smell and say"water's hot enough" :BigGrin:
    Mike.
    Hope it's the same for you,but for peace of mind I'd have it checked over.
  8. weekenders
    Apr 30, 2008
    2,218
    1,283
    Leicestershire
    Since having our van for just over a year, we have'nt had this smell before, is there something we could check to see if all ok?
  9. hilldweller
    Dec 5, 2008
    27,756
    26,847
    Macclesfield
    I'd certainly be testing the CO alarm, just in case.
    • Like it Like it x 2
  10. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,950
    I think it dumps several degrees above freezing (8 deg C springs to mind). In cold weather (like when we were away a couple of weeks ago) we keep the water heater on the low setting. Doesn't use much gas and prevents dumping.
    Probably best to get a gas engineer to look at it to be sure.
  11. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,070
    DERBYSHIRE
    Give Dave Newall a pm he should be able to offer advice
  12. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,347
    13,202
    somewhere
    thay may be along soon:Rofl1::Rofl1:
  13. FULL TIMER
    FULL TIMER Read Only Funster
    May 31, 2012
    796
    712
    NORWICH
    had a hymer in a while ago with customer complaing of a scorching smell when the combi boiler was on, in theirs it turned out to be a warm air ducting full of insulation and other stuff that mice had dragged in and made a nest with,also had a yank in at begining of the season that had a birds nest in the burner housing.
  14. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,721
    Mid Cornwall
    The burner is shot. These rot out, and when they doi, they flash back into the control module which gives the burining smell - whioch is the module housing. Take off the shroud outside, and you should have lots of soot!
    Assuming the module casing is not to badly deformed, you should get away with replacing the burner, if not it will need the burner and module. Not cheap though, look at around £150 for the part.
    I would get it in for repairt as soon as possible, and DO NOT USE.
  15. Theonlysue
    Theonlysue Funster Life Member
    Sep 14, 2009
    3,124
    2,962
    Essex
    burning smell
    I have the same in my hymer and was told by a heating engineer who already owns a hymer that this smell happens and is nothing to worry about
