Transit rear door security (1 Viewer)
IanReeves
12
Gloucester
Van conversion
Newbie
Hi folks,
Just wondered if anyone had coma across the same problem as me.
We have an old mk3 transit autosleeper, the problem is the rear door has no interior lock. You can open it, but only lock it from the outside.
No so great as that's the main entrance door.
Any suggestions ?
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
you could always get one of these Link Removed
if you remove the panel of the inside of the door and wire up through a momentary button switch then you just press the button to lock from the inside.
TheBig1
17,630
43,265
from memory the mk111 transit has central locking fitted as standard. this makes it simple to fit a locking override switch on the back door to lock cab and rears from inside. when in the cab, just press the handle in and it operates the locks for security whilst driving in unfamiliar towns etc
I
IanReeves
12
Gloucester
Van conversion
Newbie
Thanks, looks like Toolstation here I come ;)
bobandjanie
8,161
15,796
Javea, Spain
Pilote V600g
Hi, our daughter has just got herself a transit, and only had one key.
But my brother is a auto locksmith and she now has a another key and a key fob, just hits the button now inside or out all doors locked. :thumb: Bob.
Dec 4, 2007
283
17
worcestershire
Winnebago
20 years
Hi folks,
Any suggestions ?
fit a chubb locking bolt on the top of the first opening door, locking into the frame you can key lock it when leave the van
I
IanReeves
12
Gloucester
Van conversion
Newbie
Had a look under the door card today. One of the link arms had popped off so now you can lock the door from the inside and it will unlock when opened for inside. A step better than before.
Still a pain as once opened it needs to be locked again from outside, but progresses :thumb:
Will get a latch from screw fix or toolstation when I'm passing
