Transit Power Steering
Discussion in 'The Beginner' started by SmellyFeet, Jan 19, 2010.
  1. SmellyFeet
    SmellyFeet Read Only Funster
    Aug 4, 2009
    86
    8
    Norfolk
    Hi All
    Just moved my van onto the drive this morning so that I don't have to reverse it through the gate when i get home tonight in the dark. The steering felt really heavy. Didn't have time to look into it before leaving for work, does anybody know whether on a 57 transit is the pump electric or belt driven? Just to help find the cause of the problem when I get home tonight.
    Thanks all
  2. Henryhymer
    Henryhymer Read Only Funster
    Nov 22, 2007
    64
    Had a problem with my 57 transit steering last year. The drive belt had worn a small hole in the steering fluid pipe behind offside front wheel and the fluid was leaking out. Ford fixed it under warranty. Although Ford denied it was a common problem the RAC said it was common. Ford slightly re-routed the pipe so it doesn't happen again. Worth checking the pipe and see if fluid is dripping. It was only a tiny hole.
  3. hilldweller
    Dec 5, 2008
    27,771
    26,861
    Macclesfield
    Incredible - 44 minutes to a probable solution of a subtle problem.
    Not *only* FUN this place.
  4. SmellyFeet
    Aug 4, 2009
    86
    8
    Norfolk
    Thanks Henry, did turn out to be a pipe, although not one close to the pulleys. Luckily just scraped it in within warranty.
    Thanks again.
    Dave
