- Jul 28, 2008
- 813
- 731
- Ducato Sportivo
- Since 2005! 2000+ nights so far...
I am going absolultey barmy over this so any ideas welcome.
My OSF sill drain hole is constantly wet and dripping water. So much so even after being undriven for a week or so, and dry, it still drips. Suggesting >1L of water is trapped somewhere. It appears from/about the drain hole right under the driver door next to the mudflap.
Some details:-
- It comes out the same side (front) regardless of if van is parked on slope nose up or nose down, suggesting water is coming from wing area.
- The drain hole is clear for at least 20-30cm inside - beyond that I have no way of trying to follow it!
- The water is NOT anything to do with habitation area
- The water is "fresh" water, e.g. likely to be rain water or some really weird condensation problem. It is not engine coolant, screen wash
- The water is not from AC unit.
- The under windscreen drain system seems to work (e.g. captures water from most of the windscreen and sends it via a pipe to the ground)
- No water via door or cab area - it does seem to be from engine/bonnet area
I cannot see any access into any drainage system from the engine bay.
I'm guessing Its some pine leaves or something that have blocked a drain hole causing water to back up and drip slowly over time. But how on earth can I find it and clear it!
Thanks in advance
Some details:-
Thanks in advance
