Transit Chassis Tyre Pressures (1 Viewer)
mudmover
53
Wales
Low profile
OK we have a little trip to Padstow for four days........
Will check the tyre pressures before setting off...On referring to Ford Manual its a nightmare working out what are the correct tyre pressures...
To complicate further Ive heard complaints about the hard ride in the tranny
when putting correct PSI's in...
Can anybody help here?
MM
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Is yours front or rear wheel drive?
Ours is dual rear wheel drive on 185/70x16s and we put in 68 front and 48 rear.
43,304
49,293
panel van conversion, Coach built, weight etc.
all help to give answers :thumb::winky:
ooops....should have read your profile first
Jul 28, 2008
813
731
Wiltshire, UK
Ducato Sportivo
Since 2005! 2000+ nights so far...
Tyre pressure in the Ford manyal will be wrong - that will be for an empty chassis - you need the converter manual.
Or - get is weighed and get axle loading.
Then call your tyre supplier tech support line and ask them.
Every van is different based on ACTUAL tyre (differs by brand/type/loading/ply etc) and the pressure varies based on the above but especially axle loading.
Tyre companies generally give info out free and are quite helpful!
rwhites1
98
57
west yorkshire
C Cl Dethleffs Globevan
since 2001
When I bought my dethleffs globevan lowdhams said 60psi all round.Its a 6m low profile
M
mudmover
53
Wales
Low profile
Dethleffs Sunlight low profile.
OK its a 2.2 140HP front wheel drive.
The manual says 50 front and 60 rear but I cannot be sure due to number of models quoted......
The Ford is most certainly a harder ride than the Fiat chassis so I do not want to over pressure tyres and spoil ride. The positive is that the Ford is a much better drive than the Fiat!!
I'm not looking for exact just an estimate for optimum ride..
MM
Bailey58
8,798
29,359
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
Activecampers is the definitive answer, go to your local weighbridge and get the weight on each axle with your normal running load. Get the full details off your tyres and email your tyre manufacturer. I had an answer from Continental the next day. Then you can adjust a little to suit the ride.
Aug 29, 2010
845
1,246
Nuneaton. Only when I have to.
Hymer Exsis t564
Since Sept 2010
My 2008 Burstner T620 is on a Transit chassis, 140bhp 2.2 Duratorq.
Front and rear max axle weights are 1750kg and 2250kg.
Tyres fitted are Continental Vanco 215/75R 16 C 113/111R.
I emailed Continental and was advised 3.5bar/51psi on the front and 4.75bar/69pis rear.
They were very helpful and even gave me a formula for working out pressures for lower than max loading.
To quote 'As a general rule of thumb, every 105kg change will yield a difference of
0.25 pressure based on the minimum loading of 1590kg @ 3.0bar (44psi) and
the maximum loading of 2300kg @ 4.75bar (69psi).'
Email address is Administrator.Technical@conti.de and the guy who replied to me was Craig Sterry.
Hope this helps:Smile::Smile::Smile:
M
mudmover
53
Wales
Low profile
Tyre pressures
Ok this exact to my spec!
Many thx to all posters...excellent feedback!
