Traction battery maintenance question? (1 Viewer)
Nov 30, 2009
6,545
148,944
Pickering
PVC the PUG
Got my current Trojan T105 battery's from Tayna.
Great service, they swapped a dodgy 105 for me no questions asked .
I can highly recommend Trojans had them on the Mizar to cope with the diesel heating fan.
I once left the heating on after a weekend away :rolleyes: returned to the storage facility the following Friday to a nice warm van o_O
The battery's held up all week though i will add though, we also have an 85w panel but not much use in the winter months.
As for venting i have always kept them in a sealed box vented through the floor.
you can see the clear plastic vent tubes in the bottom RHS
The box was made from one of those.... Realy useful boxes from staples. I put a rubber strip round the top and made a proper lid to create a seal.
Although i love these battery's i think i may go down the Deep Cycle AGM route for the conversion i am doing.....Any recommendations ??
I see Trojan have a new one coming out but don't think they are in the uk yet www.trojanbattery.com/reliantagm/
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
i was in the same situation a while back trying to decide which batteries what swayed me was the amount of commercial companies using trojans for golf carts ,batteries must be a large expense for these companies and im sure
they have done the mathematics regarding cost not fool proof i know but so far about 20 months ive had no problems but then again im not full time
Jan 28, 2008
10,116
18,382
Renalt burstner
venting a battery space needs air flow through not at low level as hydrogen rises different if the batteries have tube fixed to them as the pressure expells fumes down the tubes in an open but sealed space the hydrogen would build up above the batteries im no expert but its what ive understood from a little research
Nov 30, 2009
6,545
148,944
Pickering
PVC the PUG
Think we have been here before as far as hydrogen venting goes....
www.motorhomefun.co.uk/forum/threads/hydrogen-venting.96909/#post-1188609
Ralph (y)
funflair
19,326
30,153
Guisborough
MORELO palace
since 2012
Thanks but not touching Gel batteries. Don't mind AGM but Gel are not good for me. Thanks tho.
You have got me interested now, what don't you like about them.
I am pretty sure our EXIDES are original on the van from new so now 9 years old.
Gromett
Feb 27, 2011
14,728
75,849
UK
Self Build
Gel batteries have a number of disadvantages. They cannot sustain high charge rates, They cannot sustain high discharge rates, they are more sensitive to charging damage than flooded or AGM. They are also more heat sensitive. Basically they are delicate little darlings with a lower life span. The only time I would use one is if there was a risk of them being tipped up.
My preferred battery type is VRLA AGM. But finding high quality ones appears to be getting harder not easier.
Forestboy
5,023
8,338
Forest of Dean
A Class Hymer B694 tag
I bought my Deep Cycle batteries from batterymegastore as well great price great service.
The moron that delivered them driving for DPD had them upside down in the van despite yellow this way up stickers all over them. Refused delivery despite the threats from the driver (moron) and phoned batterymegastore who immediately despatched another set of batteries.
Good company highly recommend them.
Gromett
Feb 27, 2011
14,728
75,849
UK
Self Build
@funflair Because I fulltime and put my batteries to heavy use I do need the best. I also charge my battery bank up using a 50Amp charger to minimise the amount of time I run my generator for in emergencies.
You are obviously very gentle with your batteries to make them last 9 years (y) I spend on average at least 9 months a year off hookup so give mine a good pasting.
funflair
19,326
30,153
Guisborough
MORELO palace
since 2012
I accept we don't live in the van, but it spends more than 6 months without hook up and just 320 watt of solar to charge, the batteries are 2x80ah and run 2kw inverter powering microwave and coffee machine and of course hair dryer. I accept that they don't like being charged as quickly as flooded lead acid but these don't seem to mind the discharge rate.
musson
487
165
grantham
low profile
since Jan 2014
try these companies for info they supply our company with traction and as we call them monbloc batteries
GNB, manbat (powercell), enersys or hoppecke all have websites they are also manufacturers
43,319
49,372
I am thinking about getting 4 of these to give me 500AH again.
Sorry if this has been pointed out, cant go through every post.
4 x 125ah wont give you 500ah.
You need to wire two batteries in series to get 12v then do the same with the other two.
Series doubles voltage but ah remains the same.
The wire each pair in parallel to double the ah.....2 x 125ah = 250ah.
You need 8 batteries to get 500ah.
Aug 6, 2013
11,953
16,567
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
I don't have an inverter. Everything I use works off 12V or only on hookup. Might have to get a small one for my leccy toothrush this year as I intend to spend a lot of time wilding.
My leccy toothbrush lasts about 6 weeks / charge.
Gromett
Feb 27, 2011
14,728
75,849
UK
Self Build
Which is great for the first 6 weeks you are off hookup. How would you manage for the next 32 weeks without hookup? :p
Gromett
Feb 27, 2011
14,728
75,849
UK
Self Build
To be fair, my situation has changed and I have to spend most of my time on sites now due to work so that inverter I got for my toothbrush charger hasn't been used since I bought it..
