Tracker eks se Gas tank retrofit.
Discussion in 'Auto-Trail' started by jenny and mitch, Feb 11, 2012.
  1. jenny and mitch
    jenny and mitch Funster
    Sep 16, 2010
    1,984
    1,736
    Bungay Suffolk
    Hi folks just asking if anyone knows about fitting a transverse gas tank, underslung across between the chassis rails.. I have seen these on the net and they don't cost too much, so I thought one of them mounted up near to where the gas locker is and connected into the regulator, with an external filler (like "gas low") would make us quite independent for touring Croatia / Spain / Portugal etc Plus it frees the gas locker for other STUFF... These tanks come in various sizes but are usually about a foot in Diameter and 3 feet long ISH.. they don't need to be re-pressure tested for at least 10 years... What do you think..? ? ? ?
    ... Mitch....
  2. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    get it from a reputable supplier after all if the wrong type of tank or bad fitting could end in an expensive fireball.
    some of the tanks used for car engine running are liquid take off where as you need vapour take off for your motorhome.
    also there are some ferry companies and euro tunnel have limits as to how much gas you can carry so be careful with the size.
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,252
    17,923
    YO11 2BD
    probably cheaper than a gaslow system and a good idea if you have a place for it.
    i believe the tanks usually have the regulator mounted on them so your existing one will be redundant and a bit of plumbing needed.
    dont forget it will add to your payload and probably weigh more than a couple of bottles (mines around 2ft x 3ft and holds 30 gallons (130ltrs)) and you'll also need various filler adaptors for European LPG pumps, which aint cheap :Sad:
  4. jenny and mitch
    Sep 16, 2010
    1,984
    1,736
    Bungay Suffolk
    Thanks Papajohn for the answer, 2ft by 3ft, thats a fair size... We have not yet managed to sell our current M/H, a compass avant-garde 120, but will be getting a tracker as soon as we do...Just doing a bit of pre emptive thinking and planning...I am the sort who can't actually start a job until I have every detail "sorted"... The less time we are dependant on sites and bottles and hook-up etc the longer we can stay away for... Next step is thinking about 2 good sized batteries OR solar, but thats another story... I think, reading all the previous on solars, I may just get 2 x 125AH batts and go for it ! ! ! The most important thing at the moment is water carrying capacity, hence swapping from our present to a Tracker.(eventually )
    ...Mitch...
  5. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,070
    DERBYSHIRE
  6. MikeandCarolyn
    MikeandCarolyn Read Only Funster
    Mar 18, 2008
    2,171
    1,463
    Worle,North Somerset
    Be very carefull with the measurements-our plan was to fit 100ltr tank between the chassis members at rear of van after removing spare wheel.When the tank was offered into position it became clear that it would end up lower than the rear axle :Smile: We didn't fancy that,so looked at other sizes.Some that were of suitable diameter were too long and vice versa-we ended up with a 40ltr tank-20kg.which when 80% full is around 16kg.
    It's turned out fine as it happens-we usually leave home about 25% filled and top up in France,then tour around for about 3 weeks and top up again before going into Spain-4 weeks touring Spain and Portugal and we got home last time with 25% left.This was Sept-Nov. All our cooking,heating and hot water is gas and we use aires more than we use campsites,so we often shower in van.
    Our filler cap is at rear of van (so no opening gas locker door on forecourt) and our gas locker holds ehu cables,Cadac bbq and various bottles of liquids (toilet stuff,waste tank stuff and windscreen washer stuff)
    Mike.
    • Like it Like it x 1
  7. MikeandCarolyn
    Mar 18, 2008
    2,171
    1,463
    After doing the fixed tank we fitted 2x80w solar panels and then,after a 2 mth trip decided that we could do with 2 leisure batts as well-so we now have 2x110 batteries and rarely actually need to hook-up.We do use EHU when we stay on a site to get washing done if it's included in price.
    Mike
  8. jenny and mitch
    Sep 16, 2010
    1,984
    1,736
    Bungay Suffolk
    Hi Mike . Many thanks for your comprehensive reply... I will indeed take care when the time comes to do the deed tank wise ... Very glad to hear that the gas lasts so well, even with using the shower in the van as we also do... Also 2 x 80 watt solars and 2 x 125 batts was my sort of long term plan too.. We will have a rear kitchen and rear shower/ washroom, so a fair bit of weight towards the back of the Tracker when we eventually get it, so I will look to getting the tank fairly midships... Take care and thanks again...
    ...Mitch... PS.. What diameter is your tank ? ? ?
