Hi my tyres are set to correct pressures but the TPMS says they're low, I think because they're lower than the stated pressure for my vehicle ( camper tyres fitted), can I reset the TPMS ? Hope this makes sense
Do you mean check tyre pressures, I check them regularly and when I start up the pressures display on the dash and are reading the same as what is in, but it says these pressures are too low, and the light stops onyes all pressures and temp alarms are setable. but the display reading is what it is. can you check it with another tester?
AFAIK Peugeot is built in the same factory in Italy as the Fiat.Hi @peterc10 I have a majestic 155 and it's a Peugeot base, I think it is factory fitted as I took it to a Peugeot and it was under warranty but they haven't fixed it, I'll have to take it back again but maybe to a different garage, I'll let you know how I get on
