Towing solution help
Discussion in 'Motorhome Chat' started by Cath bell, Jun 23, 2016.
  1. Cath bell
    Cath bell Read Only Funster
    Jun 23, 2016
    Lancaster
    What type of tow bar or towing equipment is needed to tow my Peugeot 107 behind my lunar newstar
  2. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,764
    11,965
    Plympton, Devon
    Welcome to Fun! I fear you have jumped in at the deep end as this is a controversial subject. :)
    While waiting replies it might be worth search for "A frames" on the forum as this will give you a lot of background though I'm not sure if you can search until you are fully paid up.
    However, you can get A-frames, which I think is what you are referring to, from reputable UK companies and they work fine - the issues can start if you want to go outside the UK, in particular Spain where they are considered illegal.
  3. icantremember
    icantremember Funster
    Sep 2, 2010
    5,342
    7,464
    Nr Watton in Norfolk
    • Like Like x 1
  4. vwalan
    vwalan Funster
    Sep 23, 2008
    7,601
    3,863
    roche cornwall
    what you really need is to sell the m,home and the car and get a fifth wheel set up. much better set up.
    • Funny Funny x 1
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,946
    17,612
    YO11 2BD
    10/10 for persistence Al. (y)
    • Like Like x 1
  6. wigster
    wigster Funster
    Feb 4, 2016
    1,315
    788
    Not lost but not far off
    :welcome4:. Consider superscribing to the forum , its well worth it if you need to ask questions. (y)
    At least say Hello that goes a long way.
    Think you will need an A frame .
  7. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,737
    5,967
    Mansfield,Notts
    Just for clarity and anyone NOT familiar with A framing
    A frames are not illegal in Spain! it might be better or easier to accept that
    In SpainTowing any vehicle with another vehicle however is illegal
    be it an A frame, Tow Rope, or straight tow bar, It would seam only recovery people are allowed to tow using "Proper suspended or loaded recovery equipment"
    The A frames suggested to you are Motor Home specific A frames and are accepted as legal in the UK
    I use one myself, very simple, safe , and convenient. I also have a trailer should I wish to go to Spain
    Do NOT confuse these A frames with the £100 versions on e bay sold as Recovery A frames
    or any other Recovery A frame
    As these can only be legally used for Recovering broken down cars at very low speed limits. The same apllies to Towing Dollies
    The difference between Recovery and a "Towing A Frame" is very easy to spot
    Recovery A frames require NO modification or additions to the towed vehicle and use chains or ratchet straps to atatch the broken down vehicle
    Proper Motor Home A frames ALWAYS DO need the towed vehicle to be modified to acept the towing A frame, simply put, some look better than others, it is often a personal choice based on authetices in my case, and then a choice of braking and break away methods that can be used, each Manufacture will claim his is better then others by and large they all work, if any are really better ? how do you know? unless you have treid them all, again its a personal preferance based on personal experiance or popularity and or price. in either case make sure your insurance is happy for you to tow using an A frame, and discus the value and amount of cover you need, simple trailer cover is not suffieciant in most cases. Insures expect to pay out 1 or 2 maybe 3 thousnd pounds at most for a damaged trailer certainly not 10K plus for a damaged car acting as a trailer
    Having the car and Motor Home insured with the same Company has its benifts
    G
