Towing a mini
Discussion in 'Motorhome Accessories' started by Nobby Clarke, Jul 16, 2013.
  1. Nobby Clarke
    Nobby Clarke Read Only Funster
    Jun 10, 2013
    3
    West Midlands
    Does anyone have experience of towing a mini on a trailer behind their MH? My engine is the 2.3 l, 150bhp Fiat and the mini weighs 1260kg. My mini cannot be towed on an a-frame as it has a viscous differential.
    Any comments gratefully received.
    Paul
  2. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,052
    3,452
    walthamstow east london
    ive towed lots of minis on trailers both road and race spec usually behind 2 litre transits fully loaded without any problems you need to check your maximum train weight which is on the plate attached to your vehicle somewhere
  3. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,762
    39,081
    I`m surprised you have not had an answer yet..
    Plenty of Hymer owners in the club...
    I should imagine a Mini on a single wheeled trailer would tow very nicely.... if... you are within your weight limits... for the vehicle and your driving license...
  4. Nobby Clarke
    Jun 10, 2013
    3
    West Midlands
    Thanks for the replies, I think I will rent a trailer and give it a go. Whilst I'm within the towing limits I'm cautious regarding the ability to tow the weight effectively.
    Regards
    Paul
  5. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    It won't be fast, but will do the job. Average trailer weighs around a ton, so 2.3 ton would be the effective tow weight on the back.
    You can reduce the strain on the engine, by keeping momentum going. To do this look ahead, crawl towards junctions and in traffic to prevent yourself having to stop. Weight is greater when moving from a standstill.
  6. steevie
    steevie Funster
    Apr 29, 2012
    295
    269
    Holmfirth
    just a bit heavy on that one for a modern trailer. Most two ton gross ones weigh around 500 kgs these days. trouble is here tho, the modern mini is a family saloon, and weighs nearly twice as much as the little cars usually towed behind motorhomes. A single axle one would be a bit of a hard thing to load and tow carrying a car of 1.25tons.
    http://www.brianjames.co.uk/pdf/BJT_UK_2012A_MaxPrintreadyVer4_1.pdf
  7. TheDogMan
    TheDogMan Funster
    Mar 29, 2011
    658
    366
    Rugby UK
    I tow a TA BJ Amax trailer with a Kangoo Estate on it which weighs 1280kg, a mini would be too heavy for a single axle trailer
