towing a frame problem
Discussion in 'Introduce Yourself' started by craig.drake, Oct 4, 2010.
  1. craig.drake
    craig.drake Read Only Funster
    Oct 3, 2010
    45
    queensbury
    hello just joined and picking brains right from the off ,weve just got a new vw fox and had an armitage a frame fitted great idea and easy to do until ,on our way home from lincolnshire to yorkshire it rain like never before ,then today i go to vac the car out and the passenger side footwell drenched with water anybody had this happen to them and if so what was the cure .
  2. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    Assuming you have had electronics fitted with the a-frame such as brakes or built in lights, I would check the bulkhead area and see if they have put the bung in properly, or just left a hole!:thumb:
  3. craig.drake
    Oct 3, 2010
    45
    queensbury
    thanks for that i just looked and both cable entry points and they are both are spot on vw will need to see it i think :Doh:
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,947
    17,616
    YO11 2BD
    Hi and welcome to the fun.
    i think its just a coincidence that the cars got a leak and the frames just been fitted.
    i dont know the fox but if the radio aerial is on the passenger wing then check the grommet where the coax enters the inner wing.
    you may have to do this from inside under the dash.
    i had a car (cant remember what it was now) that had the same problem.
    water running down the scuttle drain onto the inner wing, between inner and outer wings, and through the grommet hole.
    took weeks to trace it as well.
  5. laneside
    laneside Funster
    Aug 14, 2009
    3,566
    5,568
    Oradour sur Vayres
    Laneside
    Not familiar with this car but most or many cars have a drain under the vent grill on the scuttle top behind the bonnet opening line.
    This should be visible under the bonnet on the bulk head and often has a rubber bulb type drain that gets blocked up. More so at this time of year with leaves, did you by chance park it under trees---- worth a look
    Alan
