Tow or Trailer? (1 Viewer)
Deeps
11
Plymouth
Fiat Ducato Conversion
Since 2014
Hi People, just got my early retirement sorted out and now have funds to purchase a secondhand Smart Car for use with the motorhome, now my question is, does trailing the car cause more wear on all tyres and does it also increase the mileage on the trailed cars speedo, or would it be better to use a towing dolly to lift the front wheels from the road?
Do I have to use the reg no from the motorhome on the rear of the towed car or leave the cars reg on display.
Thanks in advance,
Deeps.
May 29, 2015
269
174
Worthing,West Sussex
Auto Sleeper Fairford PVC
Since 2002
Just get a trailer! I think you will find that a dolly would be illegal unless you are transporting a broken down vehicle a short distance.
Plenty of comments on here re A frame v trailer. Read then decide.
At the back of my mind I also think there is something about towing Smart cars. Have a word with. Merc/ Smart dealer first.
Deeps
Deeps
11
Plymouth
Since 2014
Thanks Poursay, shall speak to dealer tomorrow.
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
A trailer will be more expensive than an A-frame but would allow you to change cars at no further expense. A-frame will limit where you can go as some countries are undecided about their legality. Speedo should not increment when using an A-frame and tyres will wear more because they are in use but they should not wear excessively. Don’t use a dolly. Reg should change to that of the towing vehicle.
Nov 6, 2012
196
279
Guildford
3litre Bessacarr 765
Restarted 2012
Don't forget a Smart Car is rear wheel drive so having the front wheels off the ground will make no difference
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
If it is a newish Smart then you might just wreck the gearbox by towing it. I understand the older ones were OK. different system.
Jul 29, 2013
9,071
18,508
Salisbury
Hymer B678DL A class
since 2011
As Phil Collins wrote "In the air tonight" get the popcorn out I feel a new Aframe debate coming on (y) oh goody
Deeps
Deeps
11
Plymouth
Since 2014
Thanks everybody, I have googled lots of info, looks like I shall go for A frame but ensure I follow the instructions given by merc/smart prior to towing, it's mainly to ensure Neutral is correctly selected.
Roadracer2002
33
38
Northants
Low line
Since 2015
We've been towing a Smart on an A-frame for just over a year now. Best decision we made as it opens up lots of options when on site and not wishing to move the whole motorhome. Some may say tow a caravan if you want a car, but with a motorhome towing a car you have a choice to take the car or not, depending where you are going and for how long. We take bikes as well.
See many previous posts about towing vs trailer but at the end of the day you have to make your own decision.
The facts regarding A-frame towing as far as I am aware are;
1) definitely illegal in most of Europe, though some will say they haven't been stopped
2) they are not legal in U.K. Though neither are they illegal if you have towing vehicle reg plate covering towed vehicle registration, red triangles, lights working like a trailer and brakes operational on towed vehicle. With this set up the car is now classified as a trailer.
3) if you are towing a Smart car there is no steering wheel lock to worry about and so long as the car is in neutral no damage will be inflicted on the drivetrain. The central locking can be used and the odometer mileage will not increase.
Best of luck with your decision,
Hadrian
Minxy
32,646
66,526
E Yorks
Carthago Compactline
Hadrian
... and one reason why I would NEVER buy a Smart car with an A frame fitting already as you cannot tell how many miles it has actually travelled.
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Hi Took this from another thread I posted some time back. and is my Personal view on "A" frames:-
As someone who started caravanning circa 1970. And went to a R-V, when they told my wife she should no longer travel long distances without regular breaks, May I say:- I have "Toaded" all over the USA, 15000+miles in fact. Where the practice is universally accepted. I have never been able to understand the "European Phobia" against the practice. But then, That`s Europe!. (Stupidity personified IMHO). The pro`s and cons are well known, and as (allegedly) free persons we can make educated choices according to our will. There are known arguments for and against the practice. Having recently returned to the use of a Motor-home, after a 3 year break during which we had a Caravan, that which we discarded largely because neither myself nor my (disabled) wife could sit comfortably in the Seating, whereas now we have a "Captains" chair each with a leg-rest (side bench). I tow an old Punto on "A" frame. AND IT WORKS FOR US!. It is however a Grey area. having (unlike "Dolly" Frames) never been tested in the law courts. BTW, I Know from experience that my (now) rig is far quicker to set -up than a Caravan!. Unless or until they are the subject of a "test" case (as happened with "Dolly" frames) then the legality is not an issue. Any debate as to the "technical" aspect of use is just that, a debate!.
BTW. US Style "tow dollys" are completely reversible!. I know, I brought a Rental car from Florida to Texas on a "U-Haul" one, Behind the R-V when we Bought It!, It is also IMHO an even better device than an "A" frame but has been judged as "legal only for the recovery of disabled vehicles" by the Courts Circa 1975ish.
IF, I decide in the future to go back to Spain, as we did for many years prior to choosing the USA. I would likely buy a Smart and Trailer it, JUST to avoid the hassle of being "pulled" by Spanish "plod" (3 times). Someone makes (made) a trailer with a folding Draw bar, and that would take up the least space on site. ( one guy I know, put plywood base on the trailer and used it for a Gazebo, to Barbecue in / on!).
Pete
Deeps
Deeps
11
Plymouth
Since 2014
Decided not get a tow car, shall stick with the electric bikes for the time being. Sounds like too much hassle, thanks all though.
