Tow-Bars-To-Tow-Cars (1 Viewer)
icantremember
8,325
17,534
Near to Watton in Norfolk
Hymer T-SL668
since 2005
A quick temporary fix would be to get one of those 7n and 7s to 13 pin branch connectors then plug the 7n into your existing socket get a 7s socket and a length of 2 core cable and run that best you can to your habitation battery via an in line fuse using pins 3 and 4 that will give you a fully working system not elegant but will do until you get your new 13 pin socket sorted.
I already have one of THESE but of course it is the wrong way round (plugs into 13 pin socket)
I'm going to get a 13 pin socket tomorrow to replace the 7 pin on the m/h and run a temporary feed from the leisure batteries until the new year when I will do a permanent job.
ES Cumbrian
ES Cumbrian
321
143
Cumbria
Autotrail
3 years
Thats basically what I am going to do but buying a 13 pin socket pre-wired with 2 metres of cable means I can do all the connections inside, I do not fancy cold fingers.
icantremember
8,325
17,534
Hymer T-SL668
since 2005
Good thinking .... however, my existing cable runs along under the m/h so I may get chilly pinkies.
ES Cumbrian
ES Cumbrian
321
143
Cumbria
Autotrail
3 years
Mine runs under also I was going to cut it at the socket that gives me enough length to feed it through a hole under a seat, the new socket with 2 metres of cable reaches the same seat. Remove old socket and mounting bracket fit new mounting bracket and socket put heater on and do the rest inside.
old-mo
Extra Special
16,343
93,562
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Just had this sent to me from Brian, who recommended the Tow-bars-to-tow-cars system to me...
As it say`s....... Thought it was nice of him... :nod: :xThumb:
(Quote)..... There is a guy think " AT FUN" on MHF who is asking about the car to tow system which you have posted on his post. I have a wireing diagram or one which i did myself if he would like it.
If you can ask for his email address i can send it to him or anyone else who requires it..
Destination Unknown Team
Chris and Brian.
icantremember
8,325
17,534
Hymer T-SL668
since 2005
Chris and Brian.
...... and another, cheers Mo.:xThumb:
