Tow bars- 2 - tow cars (1 Viewer)
ES Cumbrian
321
143
Cumbria
Autotrail
3 years
I have just bought a Toyota Aygo with the above system on it, can anyone who has one tell me how the quick release number plate on the car works. I have a black plastic screwdriver like tool on the car key ring but no instructions.
Murphy
92
53
Mansfield
Shire Conversion
The bottom black plastic strip pulls off, you use the black plastic screwdriver to prise one end up and then pull it off the clips, the number plate then drops off and just reinsert new plate and clip the plastic strip back into place by pushing along its length, hope this helps ?
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Insert it in the slot at the bottom, and twist it pull`s out/off the thin bottom section enabling you to remove your number plate and replace with MoHo one... and just slot back the bottom bit to secure..and slide to one side... (I think that`s how it works.. :RollEyes:)
ES Cumbrian
ES Cumbrian
321
143
Cumbria
Autotrail
3 years
Thank to both of you I will give it a try once the weather clears up, I didn't want to start pulling at bits until I knew which bit came off.
ES Cumbrian
ES Cumbrian
321
143
Cumbria
Autotrail
3 years
The weather has improved from atrocious to just foul so I had a look at the number plate and the bottom does come off as the above posts. Once again thanks folks.
