My Ball is a standard two bolt fitting
That's odd. My bolt has a standard two ball fitting.
If the trailer brakes are correctly adjusted that shouldnt happen.....the extra lifting motion would be insignificant as the nose of the trailer will impose a downforce on the ball when braking due to the 'see-saw' effect.
Quite correct pappajohn.
I have asked the question of my nephew and the answer to why a riser cannot be fitted is it increases the torque applied to the mountings and bolts.
This is because of the extra leverage it can exert.
If the riser is tall enough there have been cases of the riser itself bending, and in some cases, being forced into the tow vehicle.
This does not occur with a dropper as the tow ball is already above the tow bar height, or should be, and lowering the tow ball will reduce the amount of twisting motion.
To reach a point where a dropper would significantly increase the twisting motion the other way, the tow ball would nearly be far to low, so would be no use anyway.
As I previously said, this information comes from someone who works in the industry and actually designs these things.
Oh, nearly forgot.
Any component of a tow bar would have to be type approved to go with a specific type approved tow bar for a specific vehicle that was that was registered after April 2012.
So anything that you add, riser or whatever, has to be type approved as well.
I hope that has answered any questions.
If any more crop up I will try and get an answer for you.
