Tow ball height.
Discussion in 'Motorhome Chat' started by big dave, Oct 8, 2015.
  1. big dave
    big dave Funster
    Jan 15, 2009
    32
    8
    earlswood solihull
    I have an Alco Kober tow bar fitted to a low ride Fiat chassis my question is
    the height to the top of the 50mm ball is only 34cm from the ground and I need
    the height to be approx 44cm as I have a 4 wheel trailer to give me the correct
    ride height.
  2. Speve
    Speve Funster
    Jul 29, 2013
    2,226
    1,898
    Salisbury
    you can get an adjusting plate that bolts on to your bar then fix the ball to that.
    Google adjustable tow bar.
    • Like it Like it x 2
  3. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,616
    5,840
    Guisborough
    EC directive tow ball height should be between 350 and 420 mm so it far from right, can you fit a riser plate to it or is the mounting face inside the line of bodywork.
    Martin
  4. Speve
    Speve Funster
    Jul 29, 2013
    2,226
    1,898
    Salisbury
    I should imagine it will be difficult if you have a swan neck tow bar?
    • Like it Like it x 1
  5. big dave
    big dave Funster
    Jan 15, 2009
    32
    8
    earlswood solihull
    Yes it is a swan neck tow bar,i will contact Alco Kober to see if they
    can help. I hoped someone else had overcome this problem.
  6. ciderman
    ciderman Funster
    Jul 2, 2011
    361
    410
    derbyshire
    can you let the tyres down to lower the trailer;):whistle:
  7. scotjimland
    Jul 25, 2007
    28,979
    25,675
  8. Scotties
    Scotties Funster Life Member
    Sep 23, 2008
    363
    168
    Norfolk
    I think that dropper plates are legal but riser plates are not.
    • Like it Like it x 3
  9. John Laidler
    John Laidler Funster
    Jan 9, 2013
    9,055
    12,411
    Plympton, Devon
    I think you need to look at raising the rear suspension by fitting some sort of spring assisters, such as the air bag thingies.
    I don't think you can alter the tow bar, the plates suggested above are now illegal I think and a longer swan neck, even if you could get one would act like a lever and put too much force on the mounting.
  10. scotjimland
    Jul 25, 2007
    28,979
    25,675
    are you referring to the Bulldog coupler I posted ?
  11. Badknee
    Badknee Funster
    Aug 25, 2014
    3,836
    17,179
    notloB
    Wot 'e sed.
    Swan neck extension is a no no, but air bags would work a treat. We have them fitted and if I play about with the pressures the back end rises and falls. (y)
  12. John Laidler
    Jan 9, 2013
    9,055
    12,411
    Plympton, Devon
    I don't think so, it doesn't look much like a plate. :)
  13. funflair
    Dec 11, 2013
    5,616
    5,840
    Guisborough
    As others above have said, drop plates are now illegal unless the tow bar was type approved/tested with the plate, apologies for the confusion.
    Raising suspension would do it but would be quite a lift.
    Martin
  14. scotjimland
    Jul 25, 2007
    28,979
    25,675
    So that is a no ?
  15. John Laidler
    Jan 9, 2013
    9,055
    12,411
    Plympton, Devon
    If you want a definitive answer ask the manufacturer, I've just checked on their website and couldn't see that product but perhaps they do still sell it secretly. But as the OP has a swan neck towball I guess it doesn't matter.
  16. scotjimland
    Jul 25, 2007
    28,979
    25,675
    it's a height adjustable trailer coupler,,, it is not a drop plate, so it can be used with any tow hitch.. including swan necks..
    I gave a link.. http://www.bulldogproducts.net/prod...ble-couplers/IcDNSpx3DOQo2VzPHyu4IwWo1W0O0m5u
    and not illegal or sold in secret
  17. Steve
    Steve Funster Life Member
    May 8, 2013
    1,600
    1,903
    Compton Berkshire
    Remember that it is also importent to get the 'noise' weight on the ball correct 25-50kg but again check with trailer and hitch supplyer for correct loading.
  18. John Laidler
    Jan 9, 2013
    9,055
    12,411
    Plympton, Devon
    Did I ever say it was? I was referring to drop plates and I thought I had answered that. You need to find your off switch so you can work out how stop flogging dead horses. :):):)
  19. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,852
    6,107
    Mansfield,Notts
    ScotJim has in my opinion suggested the only real solution to your problem the next viable solution would be smaller wheels on the trailer if possible
    My Ball is a standard two bolt fitting on an Alko low ride chassis and it sits at 390mm
    Jacking up suspension to tow is a non starter really.
    Illegal is a strong word, I cant see anyone being locked up for using a drop plate.
    If drop plates have such a detrimental effect on an approved tow bar, I suggest all the other toys you fasten to it, ie bike racks box carriers ect would also be "Illegal"
    Geo
  20. Gellyneck
    Gellyneck Funster Life Member
    Jun 5, 2014
    1,789
    2,217
    Scotland
    EC Directive 94/20/EC stipulates that a vehicle in ‘laden condition’ should have a towball height of between 350mm and 420mm. Same directive states that a hitch on a trailer \ caravan should have a height of 385mm to 455mm in laden condition.
    Heights are measured to centre of tow ball \ tow hitch.
    Drop or riser plates can only be used where the towbar fitment has been approved for use of these and the vehicle has also been approved. Some Land Rovers are approved as such.
    The OP's towball height of approximately 315mm is outwith the limits (350mm min) set by the Directive. On this basis a discussion should be had with the towbar fitter to understand why the fitment doesn't comply with Directive.
    The "desired" towball height of 440mm is also outwith the limits (420mm max) however the tow hitch height of 440mm is within limits.
