tour and tow ,which ones are best ?
Discussion in 'Full Timers' started by smartie59, May 15, 2010.
  1. smartie59
    smartie59 Read Only Funster
    Jun 19, 2008
    36
    Peterlee
    Hi all,
    I have a motorhome at present but it is no use to tow my cassic 69 MGB roadster.
    I am looking for a motorhome that would have 4 birth on the floor or coachbuilt 6 birth,
    as going up ladders is no good to my wife.It would have to have a 2.8+(td) as the roadster is not light and I am looking for something about 2000 to2004.Can anyone give me some models that I should be looking at?
    Thanks for reading this.
    Rod
  2. dazzer
    dazzer Read Only Funster
    Jul 30, 2007
    1,698
    99
    In my house
    Buy an RV loads of room and no worries about towing the MG and trailer. If you get a Tow Hauler you will even get a dedicated garage space ( and i do mean a proper garage not a bit of room under the bed :Doh:) and workshop
  3. takeaflight
    takeaflight Read Only Funster
    Sep 4, 2007
    256
    Stratford-upon-Avon
    Don't think the larger the size of engine, the more towing weight.
    You have to check the particular motorhome, I would start with the layout then check the weights.
    Roy
  4. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    get the car and trailer onto a weigh bridge then you know the minimum tow capacity that you need in your van.
    also a lot of vans are close to their maximum weight before you even put a towbar on the van i can only tow 1000kg with mine which if you have a car on a trailer it don't give you a great deal of choice as a small fiat sicento weighs nearly 800kg .
  5. vwalan
    vwalan Funster
    Sep 23, 2008
    7,601
    3,863
    roche cornwall
    you are definately wasting your time if you look at run of the mill campers .is you get a fiat daily they have good train wts .or go for a small truck conversion isuzu and mitsubishi make a good base vehicle .small cab not bigger than a normal 3.5 but up to 7.5 ton gvw and even greater train wts. or as dazzer says get an rv.
  6. derekfaeberwick
    derekfaeberwick Read Only Funster
    Dec 1, 2007
    1,131
    8
    Berwick
    Rear wheel drive Merc would fit the bill.:thumb:
    Extra train weight for RWD and they're better anyway.hardhathardhathardhat:RollEyes:
  7. chesterfield hooligan
    chesterfield hooligan Funster
    May 12, 2009
    1,025
    499
    Stanton Hill
    :Smile: You could look at item 180480318064 on EBAY :Smile:
    to give you some idea
  8. chesterfield hooligan
    May 12, 2009
    1,025
    499
    Stanton Hill
    :Smile: or Item number:200465873337:Smile:
