top box (1 Viewer)
stewrty
14
hello to you all i am a new to to motorhoming ex caravaner i have recenty bought a kon tiki 1990 600 with a roof rack but i need to fit a top box do i need to buy rails or is there some other way also my shower fan is not working where can i get anotherits the carver model with pull string start your help would be most helpfull thanks
S
stewrty
14
top box
very desperate got the box and need to fit it cheers
rainbow chasers
3,680
1,725
Mid Cornwall
Various
You can make add on rails quite simply assuming you can weld. We extended our rails on one of ours and adopted the same fitment as the current rails. Quite simple.
What type of box do you have? An aero type box is best, and ideally hide behind something else. If you have an air con unit, put it behind that to reduce drag. Also look at the luton, and see if it can be placed behind that. Some rise up and swoop back down, which will give so much height advantage - use that if you possibly can. It can also 'level' the roof height out - but do check if your height is effected afterwards!
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
Pardon ?
You mean there are people who can't ?
I didn't know the country had sunk that low.
Only a couple of hours ago, mate bolt with head sheared off. Weld on mate nut and remove. Surely everyone can do this.
was that Mig Tig Arc or oxy/acetylene there brian ??
have not used Tig yet but looking forward to it.
andy:thumb:
Apr 27, 2009
435
218
Departed Cabopino in Oct 17
Dakota
Fulltiming from 2010- 2017
Like you need a hole in the head really.
You don't want weight high up.
You'll probably pay more on ferries.
A bit more drag.
How desperate are you ?
Although it deeply pains me to say so, Hilldweller is right.:Sad:
Our top box is a bloody nuisance. Especially in Italy where they have many, many unsignposted low railway bridges. Only by luck have we survived without a serious crash & court case! Bin it!:Doh:
Seriously.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
andy:thumb:
MIG.
I've got an old oxy/mapgas set, somewhere, but MIG rules.
I'll admit my ali welding looks more like bird droppings, luckily I hardly ever need that. I just made a binocular mount in ali but managed to make it look good with the magnificent Plastic Padding Chemical Metal.
I used to love brazing.
