Toothed gear
Discussion in 'Hymer' started by eric 83, Mar 5, 2014.
  1. eric 83
    eric 83 Read Only Funster
    Jan 6, 2009
    90
    46
    leeds
    The toothed gear on our 1992 hymer 654 step has lost some teeth again,I welded it up and filed some more teeth on sometime ago and I don't fancy doing it again! Anyone know where I could get one from ?. I almost got one off eBay but was outbid at the last minute and can't find anyone (other than the obvious dealer ) to get one.peter hambleton say they don't sell them so help appreciated.:thumb:
  2. Tootles
    Tootles Funster
    Sep 14, 2013
    9,094
    31,896
    Lancaster
    Toothed gear?? Is this the gearbox your on about???
  3. eric 83
    Jan 6, 2009
    90
    46
    leeds
    Doh! Toothed gear on the step,I knew what I meant!! Age is a curse:cry:
    • Like Like x 1
  4. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    give me some idea of size I may be able to make one for you.
    Easiest way to repair missing teeth is to screw in some studdiing weld the studs to gether and file or mill to shape.
  5. eric 83
    Jan 6, 2009
    90
    46
    leeds
    Thanks for the offer,but the gear is pressed out of metal sheet about 4 mm thick,it is in fact only a quadrant gear.I wii be taking it of this weekend and will try and post a pic.
  6. ciderman
    ciderman Funster
    Jul 2, 2011
    359
    409
    derbyshire
    if you have welded it before then see if you can get some hard facing rods and use these to repair the teeth or even some 308 stainless rods for tig welding it. if you use mig welding it makes the material softer so wears out even quicker
    hope this helps
    andy
  7. John & Joan
    John & Joan Funster
    Mar 30, 2010
    1,238
    663
    Full Time on the road
  8. eric 83
    Jan 6, 2009
    90
    46
    leeds
