Tomtom window sticker (1 Viewer)
Douglas
2,835
400
South Wales,
6 years + 5 years in boat before that
I have a tomtom window sucker/sticker for my tom tom, but it is always falling off after about 10 days!
Has any one come up with a cure for this problem?
Doug...
JayDee
1,057
169
N. Devon
7 Years after 5 years with caravan.
I had that...
I cleaned the window where the suction cup goes with meths.
Cleaned the suction cup with soapy water, rinsed well and dried it with something lint free (clean tea towel, clean hanky).
When everything was dry, made sure the suction cup was pressed firmly against the window and then flicked the lever.
If the window gets warm, the bit of air still trapped between the cup and the window will expand and reduce the amount of suck, so I suppose you should do all the above on a hot sunny day. Hmm! better do it in Spain then. ::bigsmile:
John
dsno
Add a bit of lick
I agree that the surfaces have to clean, but then you have to moisten the rubber seal on the TT bracket, ours has been on for months with no problem. If by chance you have a Fiat cab with the map holder in the centre, then a plate trapped by the map clip, with the TT bracket fied to the plate brings it much closer to you, than being on the w'screen, also easier to dismount when parked. hope this makes sence and helps.
43,329
49,444
dead easy.....
as any kid with a bow and sucker arrows knows.....lick and stick.
mines been on for weeks now and its a BIG, HEAVY tomtom.
DESCO
2,646
266
London
low profile
18 years +12 years tugging
dead easy.....
Must agree first thing I learnt with suckers you cant beat a good lick.
Dave:thumb::thumb:
Bursted
3
Isle of Man
Doug...
If you have a std Ducato, turn the sucker upside down and clip it to the paper holder thingy on the dash, works fine for me:Smile:
Douglas
Douglas
2,835
400
South Wales,
John
No leaver, it's just a push fit.
Doug...
Douglas
Douglas
2,835
400
South Wales,
dead easy.....
If that's the best you can do you should not have bothered, but thanks anyway.
Doug..
Sweet Chariot
572
5
Staffordshire Moorlands
since 2006
I have super glued an old CD to the plastic cup which you fasten to the window and clipped this under the lift up Map/note reader on the dash works fine.:thumb:
Douglas
Douglas
2,835
400
South Wales,
Yes I have thought of using superglue, but if it does not work will I be left with marks on the windscreen that can't be removed.
The position on the lift up map holder does not appeal to me.
Doug...
Emmit
8,034
17,753
Cornwall
Pilote Explorateur
Jan.2014
Greetings,
I heard all sorts of horror stories when I was in the market for a Sat Nav. It revolved around toerags being able to see the sucker marks and working out there was a sat nav on board.
(Pity they can't use their observational skills to an honest use!)
However, my Sat Nav (A Becker ) came with a plastic disc similar in size to those seals for the tops of cans. I got a mate who is a wood turner to turn me a can shaped piece of wood that EXACTLY fits into the cup holder at the front of my chariot.
Glueing the plastic disc to the top was simplicity itself and the Sat Nav cradle sucker is put on top of the disc.
Its in my eyeline (just) and can easily be removed when parked without displaying any visible signs of its use.:thumb:
savantuk
735
42
Cumbria, Lake district UK
30 years.
The mount on my Garmin is as solid as a rock with it's lever lock. I know that this doesn't help much, but several 'aftermarket' mounts similar to the Garmin are available for the Tom Tom.
Here's one for less than a fiver!!
Link Removed
