Jaws
- Sep 26, 2008
- 23,832
- 72,341
- C class, Chieftain
- since 2006 ( I think ! )
The TT is very fussy about the USB connection used, if you are using a USB hub, it will almost certainly fail.OMG !! It has done it this time !!!!
Took almost exactly two hours to download and update 64k of data !!!!!!!!
Hate to think how long a new map set would take to do
Did you leave the hub plugged in? This can cause the USB enumerator to become confused. May be worth disconnecting it next time.Nope.. going straight in to the USB socket on the computer.. The hub is only used for printers, cameras and other gadgets
I hadn't thought about that. I have always wondered whether they use the same server to serve the "live" units and the update requests. The live traffic frequently gets server errors at about 9 in the morning and 5 in the evening, or put another way, exactly when you want it!Perhaps it is just a case of the TT chucker running out of resources early in the morning
Woman can play with the TT
Wait until you get a full map update.OMG !! It has done it this time !!!!
About
. can't put post codes in.........aaaargh.
When I could not get postcodes I called the help desk and they sent me a file. Everything worked fine after that.
For what it is worth some browsers work with TT and some don't.
