TomTom 13.030 is now available for the GO 400, GO 500, GO 600 (1 Viewer)
andynkim
107
200
Mobilvetta K-Yacht 85
Hi all
Lat and Long navigation now available.
New software
Software version 13.030 is now available for the GO 400, GO 500, GO 600, GO 5000, GO 6000.
Version 13.030
(GO 400, GO 500, GO 600, GO 6000, GO 5000)
My Routes
We have added My Routes to the GO. You can use My Routes to save, retrieve, edit and delete routes, including itineraries with multiple stops.
How to save a route to MyRoutes:
Plan a route using search or the map view. This can be an itinerary with multiple stops.
You can save the route in two ways:
In the Main Menu, select Current Route, then select Add to My Routes.
In the map view, tap the route then select the pop-up menu button. In the menu, select Add to My Routes.
Give your route a name so that you can easily recognise it.
Select Add.
In My Routes in the Main Menu, the new route is saved in your list.
How to make and save changes to My Routes:
Select a route from My Routes.
In the map view, change the route, for example, add or delete a stop, or use a different location as the starting point.
Tap the new route, select the pop-up menu button and select Save Changes to Route.
The changes to the route are saved.
How to delete a route from My Routes:
Select My Routes in the Main Menu.
Select Edit List.
Select the route that you wish to delete.
Select Delete.
Reorder stops (itinerary planning)
When you have planned a route with multiple stops, you can now adjust the order of the stops.
How to reorder stops:
Plan a route with multiple stops or select a route with multiple stops from My Routes.
Select Current Route in the Main Menu, then select Reorder Stops.
In the map view, you see route with the stops that are included on your route.
To change the order of the stops tap the stops in the order that you want teh new route to follow.
Your route with new order of stops is then shown.
Select the steering wheel button to start navigating.
Drive to a route
When you have planned a route from a starting point that is not your current location, you can now drive to the start of that route. Select Drive via here, to plan a route from your current location to the starting point of the route, and start following the route.
How to drive to a route:
Plan or select a route with a starting point that is not your current location.
Select Current Route in the Main Menu.
Select Drive via here.
In the map view, your route is changed to start from your current location and then follows the route you selected or planned.
Navigate to latitude longitude coordinates
In the search box, you can now enter a specific set of latitude longitude coordinates.
How to navigate to latitude longitude coordinates:
To the right of the search box, select the type of search. By default this is set to Current map.
Select Latitude Longitude.
The keyboard changes to a special keyboard for coordinate entry.
As you type in the coordinates, suggestions are shown based on what you have typed. You can continue typing or select a suggestion.
The line under the code turns red if the coordinates are incorrect and turn blue when correct.
The example under the line helps you to type in the correct code.
Select a suggestion for your destination then select Drive.
Warning sounds when speeding
You can now both see a visual warning and hear a warning sound when speeding.
0-5 km/h too fast: the speed panel turns orange.
> 5 km/h too fast: the speed panel turns red.
Now you can also choose to hear a warning sound when speeding:
> 5 km/h too fast: you hear three beeps.
The warning sound can be turned on and off in the Main Menu.
How to turn warning sounds on or off:
From the Main Menu, open the Settings Menu.
Select Sounds & Warnings.
Select Safety Warnings.
Select When Speeding.
Choose between Always or Never
Time-dependent speed limits
We now offer time-dependent speed limits in the following European countries: Germany, Poland, Sweden and the Netherlands (requires map version 9.20 or higher).
If you are driving in these countries, the speed limit in the speed panel changes depending on the time of day.
Other bug fixes and improvements
Improved route re-calculation
We have optimised the re-calculation of routes.
Andy
