Tom Tom XXL meltdown
Discussion in 'GPS Navigation' started by ninjayorkies, Jul 16, 2011.
  1. ninjayorkies
    ninjayorkies Read Only Funster
    Mar 28, 2010
    533
    148
    Lutterworth
    Set off for Littlehampton this morning and 20 mins into the journey my display disappeared and up popped a page of nearest police stations etc without me touching the device. After a lot of button pressing i got back to my route display but it continued to go to different pages so I switched it off. After a while I tried it again and managed to key in the postcode but it started to play up again and eventually I couldn't get away from the pages it was bring ing up - nearest this that & the other, walking directions to places I've never heard of and a load of stuff about agreeing to map corrections. The voice is still working to tell you where to go but it's got to the stage now where the device is putting digits in the destination and not me. It's ust over a year old and seems to be as much use as the box it came in which I'm not happy about at £180. Any ideas or suggestions would be much appreciated. Sorry for the long winded explanation.
  2. champers
    champers Funster Life Member
    Mar 9, 2009
    3,468
    2,098
    Wales
    Hi there is a reset hole on mine (nr where you sit the base into it ...is a pinhole) I use a unfolded paperclip into it, and hold about 4 or 5 secs i think it was
    or i would telephone tomtom helpline, they are very helpful( they taught me the tip about the reset )
    hope you get it sorted quickly
    Kath
  3. ninjayorkies
    Mar 28, 2010
    533
    148
    Lutterworth
    Thanks. I've reset it but also emailed their tech support. It's behaviour is so weird it's hard to describe
  4. MrJinks
    MrJinks Read Only Funster
    Sep 1, 2008
    582
    115
    Dorchester, Dorset
    Have you got it linked to your computer. ie "TomTomHome"
    If you had, your data & setup would be backed up there. You could then reload your TomTom.
  5. scotjimland
    Jul 25, 2007
    28,934
    25,589
    Clean the pizza and fish 'n chip grease stains off the screen.. :Wink:
    seriously.. is it dirty ? could be the problem..
  6. ninjayorkies
    Mar 28, 2010
    533
    148
    Lutterworth
    Not dirty as it still has the screen cover on it. I haven't hooked it up to my computer yet but should do for map updates
  7. betty swallux
    betty swallux Read Only Funster
    Nov 5, 2010
    49
    45
    Scotland
    The STD number for Tom Tom is 020-7387-5444, give them a ring and ask for technical assistance they can usually talk you through a fix if one is possible.
  8. MrJinks
    Sep 1, 2008
    582
    115
    Dorchester, Dorset
    It might be too late then.
    They charge for map updates. Expensive they are too unless you got any free map update package when you bought it. But system updates are free. If you can't get any sense out of it you could always try a system update but as I said it may be too late.:Sad:
  9. scotjimland
    Jul 25, 2007
    28,934
    25,589
    what screen cover ?
    Don't recall mine having one.. unless you mean the thin protective plastic which AFAIK should be removed ..
  10. ninjayorkies
    Mar 28, 2010
    533
    148
    Lutterworth
    I think it's just under £20 for 4 map updates + 2 free
  11. MrJinks
    Sep 1, 2008
    582
    115
    Dorchester, Dorset
    Yeh, your right.
    That's a lot cheaper than they used to be. :thumb:
  12. ninjayorkies
    Mar 28, 2010
    533
    148
    Lutterworth
    That's the one :Eek!:
  13. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,324
    YO11 2BD
    i'm sure that is just a packaging protective film and should be removed when first unpacked.
  14. freelanderuk
    freelanderuk Read Only Funster
    Sep 24, 2009
    1,022
    541
    Saltfleet/Lincolnshire
    remove the screen cover and all should be ok if not get a sheet of printer paper and go round the outer edge of the tomtom screen with the corner the paper, sometime dust particals and bits of dirt can cause the same effects
Similar Threads
  1. laurieash
    9
    437
