Tom-tom map probs. (1 Viewer)
GIBLA53
267
25
Powys/Spain
Adria Coral Compact
since 2002
HI JUST A WARNING TO ANYONE WITH A TT. 720 GO . IF YOU SUBSCRIBE TO MAP UPGRADES BE AWARE THAT THE LATEST UPGRADE WILL COCK-UP YOUR DEVICE. WHAT HAPPENS IS THAT YOU CONNECT AS USUAL THE VARIOUS UPDATES ON CAMERAS ETC ARE DOWNLOADED , THE OLDER MAP IS TAKEN OFF THE NEWER MAP PUT ON AUTOMATICALLY THEN AFTERWARDS A MESSAGE APPEARS ON YOUR DEVICE "YOU CANNOT USE THIS MAP ON THIS DEVICE" RESULT=KAPUT. THIS IS A KNOWN ISSUE ON 520/720/920 DEVICES I PHONED TOM-TOM THIS MORNING AND THEY ARE WORKING OUT A SOLUTION --NONE IS PRESENTLY AVAILABLE BE AWARE:cry::cry::cry:
S
sinbad1
I guess with any upgrade a backup is essential:thumb:
GIBLA53
GIBLA53
267
25
Powys/Spain
Adria Coral Compact
since 2002
Silly thing is it is backed up ,both new and old maps are stored but Tom-Tom application wont let you instal the older(working) map to the device . I had deleted the new map off the device but there is no way to re-instal the old map even though Tom-Tom stored both on my laptop . Alan:Doh:
Pikey Pete
1,481
1,143
o
o
I have a GO720T and have upgraded to Western Europe Vers. 830.2305 with no problems. Which map version caused the problem ?
Can you not rebuild from your backup map ?
Pete:Cool:
scotjimland
2,320
10,003
A Woosh bang
This is probably due to the map protection that TT use to prevent using updates on more than one unit .. or selling them on .. in your case it's probably deleted the old key for your original map so it won't re install... :Sad:
hope that made sense and you get it resolved soon
jim
GIBLA53
GIBLA53
267
25
Powys/Spain
Adria Coral Compact
since 2002
Same version ie. 830.2305 is what i am trying to instal , i have tried a re-instal by removing still no joy . I did have this map available for maybe 2 weeks but 3 dongling not appropriate for 1.7gb. tried at brothers broadband did it in 2 hours but even though a secure steady supply it stopped and had to resume 2-3 times dont know if this resulted in a corrupted download. Alan
Pikey Pete
1,481
1,143
o
o
I had a problem with an earlier upgrade in similar circumstances, but not with the message you have. Mine just would not start at all. I ended up having to reformat the drive and then reload from an earlier backup. Worked for me at the time.
Pete:Cool:
S
sinbad1
have a look through these click here
Sometimes a hard reset can sort things out?
TT tech are fairly good at sorting out problems
it could be your TT is corrupted as you say, at one time i had a similar problem, and had to use the TT clear flash tool which sorted it out .
click here
Be sure to follow the instructions carefully if you use this tool
regards
duetto owner
216
north surrey
hi top
in first year
how to please
having never updated my TT700 europe maps what is the procedure to update the maps does it go to any particular folder?
