Tom Tom help please (1 Viewer)
Lampie
169
Derby
C Class RV
Anyone got any ideas on this.
Tom Tom one voice instuctions no longer work. the unit says it is switched on. Have tried to re set the unit but still no sound
Lampie
Phil
226
Herts
10 years
Hi, if your TomTom has a headphones output you could try plugging in there and see if you get anything. If you do it probably means the internal speaker has failed or become disconnected, then take it back if still under guarantee.
I always use a couple of small amplified speakers connected to mine, helps to hear it above the noise from the diesel :Smile:
Phil.
hogan
204
Valencia,Spain
Are you using the tom tom with a bluetooth mobile phone if so turn phone off then re boot tom tom if this then works ok download latest operating system and mobile phone update
oldun
747
162
St Neots
VW Campervan
Since 2001
I have a MIO A201 running TomTom 6 and have no external devices attached either mechanically or by Bluetooth etc.
Occasionally we get the same problem - the voice disappears and nothing that I have found will bring it back except for a hard reset
X
Xoxoc
Have you tried changing the voice used? Go throught the preferences and select a different voice. It could be that the voice file selected is corrupt (unusual but worth a try.)
Also, double check that you haven't disabled sound OR turned volume right down... Don't laugh - it's been done before :Smile:
