Toilet flush broken (1 Viewer)
barrywi
120
28
Cumbria
C class
I am a Newbie to motorhomes but have caravaned for years
On holiday in Holland and on the first flush of the electric toilet no water comes out. The motor whirs so 12 volts is there but no water comes out of the spout. It is a thetford so any clues before I hit their website?. Not sure if the pump is easily accessible as the motorhome paperwork does not have the Thetford toilet book.Luckily we have wifi here. Great site next to river Lek and Lekkerkerk. 13 euros a night including electric , hot showers and wifi that works. Are you listening Caravan Club.? Called camping De Nes. AND the sun is out too. Has Scotland gone yet?
haganap
12,757
26,436
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
not sure what van you have barry but onmine there is a similar situation what you need to do is access the pump and you may well find that one of the pipes has come off the pump so therefore it is working but just not pulling water you can access it at the blue button at the top there is a little bit of a gap ritchie prize open there is in this some sticky stuff 2 hope that helps good luck off to holland in 5 weeks can't wait
Apr 13, 2012
5,542
18,767
Mobilvetta Euroyacht
1996, then break 'til 2011
Use a saucepan or kettle .............
To Flush !
:D(y)
barrywi
barrywi
120
28
Cumbria
C class
Yes there is water in the tank as I said, and I know I could use a pan, but I hate things that do not work. Thanks for the guide to where the pump may be, on a quiet day I will get my toolkit out!
Nov 18, 2011
11,862
42,906
Planet Earth
A van
Over 25 year's
on my van there is a fuse in the casket cabinet my one stopped working I replaced the glass fuse
edit as haggers says probably a hose or blocked pipe
bill
Badknee
7,407
412,357
notloB
Vantage Neo
Living the dream.
Can't be much wrong if the pumps running :)
Keef
33
13
Hereford
Low profile
15 Years
Had the same problem, took the van back under warranty and they came to the conclusion that the water wasn't high enough even though we had put around three or more litres in
tambo
874
639
Dunfermline fife scotland
a class
MH Since 2008, ex tugger and vw campers since 1992
My flush comes straight from my water tank and uses the same pump as the fresh water etc
I'd check to make sure the supply hose hasn't come off and pumping water elsewhere
barrywi
barrywi
120
28
Cumbria
C class
Thanks for the suggestions everyone. Delay in replying due to internet service here going offline.
Took off the top plate as told , undid four screws which then allow you to pull out the pump. I looked at the end of the pump and was turning when the button was pushed, so put the pump into a water container and lo and behold it pumped water! Put it all back together again and everything is fine. Don't know why it did not pump before, no pipes off and plenty of water in the tank so maybe just moving everything sorted it. Have also glued back on an edge trim and the site has fixed the internet. Three things fixed in one day and a lovely trip around Rotterdam in the sun with our Dutch friends ....result. Lovely place to visit.
barrywi
barrywi
120
28
Cumbria
C class
Still sunny in Holland ,24 degrees centifried today!
