Toilet cistern help
Discussion in 'The Beginner' started by Lilian, Oct 4, 2015.
  1. Lilian
    Lilian
    Sep 16, 2015
    15
    4
    South Shields , Tyne and Wear
    Hi ....can anyone help!!! We've got a 1999 Elddis suntor SE and don't know how to fill the cistern up....had tourers before and thought they'd be very much alike...Wrong.....know how to empty it but where do you fill it . Got an onboard water storage but can't find any taps or such to turn on to fill the cistern.....nothing in the manual either to help .
    Thank you .....xx
  2. mickyc
    mickyc Read Only Funster
    Nov 30, 2009
    566
    2,014
    Spain/Portugal
    Don't know about your specific model however .......
    It will either have its own tank (access to filler usually in the same hatch as your cassette)
    Or it will be run via a pump from from your main water tank.
    • Like Like x 1
  3. Lilian
    Lilian
    Sep 16, 2015
    15
    4
    Thanks mickyc.....hasn't got a filler and the pump seems to be working but no water X
  4. mickyc
    Nov 30, 2009
    566
    2,014
    Spain/Portugal
    Hmm, I'm assuming you have some water in your main tank?
    Are there any unidentified filler caps on the outside wall (near the loo?)
    Does loo sound like it has its own pump (different noise to tap pump)?
    • Like Like x 1
  5. Lilian
    Lilian
    Sep 16, 2015
    15
    4
    Yes got a full tank and nothing in or around the waste part of it .....and when it pumps it makes a whirring noise, different from the taps .x
  6. mickyc
    Nov 30, 2009
    566
    2,014
    Spain/Portugal
    I've google imaged your van, are you sure you don't have another water fill point above the cassette access hatch on the outside of the van?
    • Like Like x 1
  7. mickyc
    Nov 30, 2009
    566
    2,014
    Spain/Portugal
    Most of the elddis images appear to show a filler above the loo as in this image
    [​IMG]
    • Like Like x 2
  8. jollyrodger
    jollyrodger Funster Life Member
    Oct 1, 2012
    3,557
    7,064
    Plymouth
    Maybe a couple of photos could help :)
    • Like Like x 1
  9. Lilian
    Lilian
    Sep 16, 2015
    15
    4
  10. Lilian
    Lilian
    Sep 16, 2015
    15
    4
    Are these any good ....really appreciate your replies, cheers X
  11. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,383
    9,829
    the swing out spout above the cassette
    oops just zoomed in. yours is tank fed. if its not flushing, you need to check it has power. common fault is the valve jams too
    • Like Like x 1
  12. CWH
    CWH Funster Life Member
    Jan 29, 2014
    2,907
    11,693
    under a wand'rin' star
    ..... is for emptying & for "charging" the cassette with 2 litres of water & blue chemical (well, it's 2 ltrs on ours which is the green one)
  13. jollyrodger
    Oct 1, 2012
    3,557
    7,064
    Plymouth
    OK so no outside fill point or swing out filler for its own tank .therefore should be fill from main Water tank with push button on top of toilet body or a remote switch inset into the furnishings?
    It maybe its own pump is us
    • Like Like x 1
  14. mickyc
    Nov 30, 2009
    566
    2,014
    Spain/Portugal
    • Like Like x 1
  15. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,717
    17,331
    YO11 2BD
    Have a look <HERE> for a full explaination of how to repair the flush.
    My apologies...wrong C200 model.
    • Like Like x 1
  16. Lilian
    Lilian
    Sep 16, 2015
    15
    4
    :glitter:Everyone xx
  17. Badknee
    Badknee Funster
    Aug 25, 2014
    3,713
    15,980
    notloB
    From the outside it looks just like ours Lilian. The flush water comes from the main tank as has been said, so, if pump starts and produces water into the bathroom sink happy days, listen to the noise it makes while your stood in the bathroom then press the toilet flush button and it should make the same noise and flush the loo. If it's not the same noise there could be a blockage somewhere after the pump but before the loo. (y)
    Edit, if you can't get it fixed don't let it stop you using your MoHo, just flush with water from the sink.
    • Like Like x 5
  18. Lilian
    Lilian
    Sep 16, 2015
    15
    4
    Cheers Paul .....got a big bottle of water in the bathroom lol (y)(y)(y)
    • Like Like x 1
Similar Threads
  1. Dan16
    13
    511
  2. Jasonsmall007
    6
    355
  3. stringa
    4
    342
  4. Scaniaman
    44
    2,217
  5. Nigel L
    63
    2,956
