Todays daft question: Where's my water tank gone!!?
Discussion in 'Tech/Mech General' started by RichardB, Apr 5, 2015.
  1. RichardB
    RichardB Funster
    Oct 19, 2013
    203
    108
    East Yorkshire
    Hi all
    Spend the weekend getting our new to us Elddis Sunquest (Autoquest) 100 (2011 model on a 2012 plate) ready to go away next weekend. Had a play around with all the bits and pieces and everything looks to be working well.
    Tested all the taps and the shower and then it ran out of water.
    When we picked up the van from the dealers he showed us what to do fill up but just to be on the safe side I had a read of the manual.
    It says that I can check the current water level of the inboard 45l fresh water tank. It also recommends that you watch the water tank when filling so it doesn't overfill and that it is located under the side bench seat.
    All ready to fill, I connected the filler hose to the tap, dispatched the wife to watch the water tank didn't overflow and was just about to turn on the tap when she says "There's no water tank under the seat" - trying to describe what she should be looking for, she was certain there wasn't anything that looked like a tank only a red plastic box.
    So I went into the van to check what was under the seat and I saw....
    [​IMG]
    Yes, where I thought the water tank should be is a wooden tray and the red box has a breakdown warning triangle in it. To the far right of the picture you can see a red and blue water pipe disappearing through the van floor. To the left is the whale pump and stuff and in front is the electric fuse board.
    So, I have a handy place to store stuff but where has the water tank gone?
    At the other side of the van, one seat has nothing under it and the other has what I think is the water heater and some other blown air pipes.
    I struggle to get under the van, but from what I can see there is only a waste water tank - I will try and trace the fresh water drain tap tomorrow, but in the meantime does anyone else have an Autoquest 100 of similar age, where is your water tank? whats under your bench seat? and does anyone know if Elddis offered this as an upgrade?
    Richard
  2. Bill_OR
    Bill_OR Funster
    Dec 11, 2011
    519
    709
    Nr Hastings, East Sussex
    did you find it?
  3. scotjimland
    Jul 25, 2007
    28,940
    25,628
    hmm if that is the case that is poor design.. it should either have an overflow pipe, or just fill until it comes out of the filling point.. why would you need to watch it inside the van ?
  4. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,286
    7,990
    West Norfolk
    Your water tank will be hanging underneath somewhere.
  5. chaser
    chaser Funster
    Feb 16, 2013
    7,714
    8,789
    uttoxeter
    I know it's a totally different van , only thing in common , made by eldis, but our water tank is in the wardrobe, hth.
  6. lunarman
    lunarman Funster Life Member
    Sep 23, 2008
    1,484
    888
    South Glos
    edited looked at picture again under tray is that the wheel arch@
  7. Mr Colpot
    Mr Colpot Funster
    Apr 29, 2009
    703
    255
    West Sussex
    mmmm - I wouldnt expect to see hot water pipes on the cold water tank - on our 2003 Elddis Sunseeker25 the boiler was under the seat and the water tank was under the wardrobe but that was an older van.
  8. mike mcglynn
    mike mcglynn Funster Life Member
    Jan 6, 2008
    1,431
    6,045
    St. Helens MERSEYSIDE
    Hi,Richard we had an autquest some years back and the fresh water tank was under the wardrobe acessed via a wooden lid hidden away from view you could not see it from underneath the van as it was an internal tank shaped to fit behind and under the hanging space of the wardobe ,I just used to fill the tank to the brim and some came out from an overflow thats when I stopped filling.:)
  9. chaser
    chaser Funster
    Feb 16, 2013
    7,714
    8,789
    uttoxeter
    Yeah that's the one we have.
  10. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,968
    In our 2004 Autoquest 100 the water tank was under the rear facing dinette seat. The location that Mike and Chaser describe (wardrobe) is for the rear lounge model.
    In each case the fresh water tank is just inboard of the filler inlet as shown at section 6-6 of the Handbook.
  11. RichardB
    RichardB Funster
    Oct 19, 2013
    203
    108
    East Yorkshire
    Hi all
    Had a look under the van today and seem to have found the waste and fresh water tanks.
    Both underneath, which is not where the fresh water should be according to the manuals!
    The picture below shows the 2 tanks - the left one is the waste. The right one is the fresh water and the white pipe goes to the drain down tap.
    [​IMG]
    Still not sure why there underneath - maybe previous owner put in bigger tanks…
    Richard
  12. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,116
    17,785
    YO11 2BD
    NEVER believe what is written in a manual....things get moved but rewriting manuals is expensive.
  13. scotjimland
    Jul 25, 2007
    28,940
    25,628
    also, a lot of manuals are generic for several models from the same stable ..
