Toad Number Plate fix? (2 Viewers)
johnsandywhite
1,720
19
Doncaster/Spain
'A' Class RV &
:Sad: This will be the first time we have towed a Toad to Europe. Done a local (60 miles) twice and broke the rules in that I didn't put our extra Motorhome number plate on the Toad. How do YOU fit yours?
I was thinking of Rubber Bands made of old tyre inner tubes. But nowadays they are like hens teeth.
I also thought about fitting clipboard clips on and sliding it over the Toad number plate.
I then thought about fitting normal Plastic number plate bolts through from the back of the Toad number plates and then bolting on the Motorhome plate. What do YOU use? :thumb:
Jim
Ringleader
Jul 19, 2007
36,417
130,897
Sutton on Sea, UK
Adria Panel Van.
Since 1988
We use an old innertube for our trailer, but its push bike innertube, you must have one of those knocking around all that cycling you do:Smile:
Boo
633
4
Cornwall
A cls
9 years
I replaced the numberplate bolts on the rear of the toad with 2x 1.5 ins threaded bars of which my original plate fits to, that leaves around a 3/4ins thread stuck out so I just put the RV reg plate on top of the car number plate and fix with locknuts.
Hope that makes sense :winky:
Boo
johnsandywhite
johnsandywhite
1,720
19
Doncaster/Spain
'A' Class RV &
:Doh: Thanks Jim. Yep. Thought of that. But ALL our old inndertubes are in Spain. :Doh:
scotjimland
2,324
10,061
A Woosh bang
Hi John
you can buy proper metal spring clips that fix to the MH plate and clip over the toad's plate.. I'll look for a supplier or post a pic if you can't find
Jim
johnsandywhite
johnsandywhite
1,720
19
Doncaster/Spain
'A' Class RV &
Hi John
Jim
:Smile: Thanks Jim. I did think there must be something around like Clipboard clips to fix the job. :winky:
scotjimland
2,324
10,061
A Woosh bang
Here's what your looking for John :Smile:
Link Removed
Link Removed
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
We use the yellow plastic number plate bolts,they are fitted through the toads plate, then holes drilled in the RV plate with black plastic thumb screws holding it in place. Best part of this is,no rust,and looks tidy.If it looks tidy "they" leave you alone.
Nov 6, 2008
3,943
40,801
Ramsey, Isle of Man.
Coachmen Concord 300TS
8 years with an RV
Have you tried number plate sticky pads? They sure do stick. Most places that make number plates supply the pads.
johnsandywhite
johnsandywhite
1,720
19
Doncaster/Spain
'A' Class RV &
:Sad: Yep. They had the KIA Toad number plates fitted with these. The few Hot days they had here made them drop off. They WOULD not be suitable for use in Spain. Our son Simon even fitted special double sided tape all the way across the plates and they STILL fell off. I think it was down to there being a slight bend in the bodywork. :Angry:
charlie24
61
Maryburgh, Ross shire
1 year
In my previous life as a Police Officer it was legal to run with different numbers on the towed vehicle as long as you owned both. Has this changed?
johnsandywhite
johnsandywhite
1,720
19
Doncaster/Spain
'A' Class RV &
:Eeek: I wasn't aware of that charlie24. In the old days people used to stick a piece of cardboard with the Reg number in the window of the caravan or on the rear end. Same with a trailer. :whatthe:
scotjimland
2,324
10,061
A Woosh bang
Probably not,
but in order to comply with the trailer regs., which an A framed car must do, the towed car has to have the same plate as the towing vehicle.
jim
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
there could be an issue here of was the aframe being used for recovery .if it was you dont normally worry about the n,plate. recovery brakes lots of rules we now have. alan.
itexuk
73
Taunton Somerset
Fiat x250
Give Towtal a ring 01782 333422
They do a number plate holder that you clip your number plate in to.
You unscrew your old number plate, screw the number plate holder to your car, then clip in your Motorhome number plate. When you get where you are going just unclip your MH number plate and clip in your toad plate. All very easy
johnsandywhite
johnsandywhite
1,720
19
Doncaster/Spain
'A' Class RV &
::bigsmile: Thanks everyone. Because I have spent so much recently on our new-to-us Suntor and the KIA Toad, plus 4 extra batteries and Solar panel etc. I have decided to go the CHEAP route. ie: Fix some Plastic number plated bolts through the back of the Toad number plate and then screw on the Suntor number plate. Cheap as chips. :RollEyes:
43,329
49,444
Link Removed
Link Removed
i have a pair of these on my bike trailer.
DONT rely on the clips alone....they are rubbish at holding your plate in place.
first time out cost me a new plate:cry:
file a shallow notch the width of each clip, top and bottom, in the plate where the clips sit so it cant move sideways and fall off.
i also have a very small 'doglead' type clip on a short wire which clips through a small hole in the number plate just incase it happens again.
on my toad i use a couple of lengths of knicker elastic tied in a loop and slip over both plates....works for me:thumb:
43,329
49,444
yep!
she's still in 'em.
you dont think id trust a couple of bits of knicker laggy on their own, do you?
quicksam
23
Kiskunhalas - Hungary
4 years
Probably not,
jim
Hi Jim,
Just a thought, how do tuggers from the Netherlands comply, they have a separate / different registration number for their caravans / trailers ? :Doh:
Sam
43,329
49,444
Hi Jim,
Sam
same way as UK plates are yellow with black letters/numbers at the rear but it appears most of europe are white/cream with various different coloured numbers/letters depending on country.
there are exceptions to the rules.:thumb:
johnsandywhite
johnsandywhite
1,720
19
Doncaster/Spain
'A' Class RV &
:Cool: As I ahve already mentioned, I am going the Plastic number bolt way. 6 for £1.49 as opposed to £5.99 for a pair of nice looking but don't trust them alli clips. :thumb:
