Confused here?
A frames, yes I know, discussion closed
Wiring up my Jeep Wrangler for A framin and....
Simple enough, there is a wire with a plug on each end on the A frame, so a socket on the front of Wrangler wired into the rear lights, which for ease frankly I just ran back to Wrangler's own tow socket, all colour for colour/correct wiring code etc.
So, known good trailer board in tow vehicle, tests fine, Wrangler's rear tow socket, fine, Wrangler's front socket fine, connect to tow vehicle and not fine.
Stop and tail are fine but indicators, either way both on Wrangler flash together about half brightness, stop or tail flicker in unison if on.
Use Wrangler as primary, ie make like she's tow vehicle and test vehicles lights do exaclty the same.
Tryed Wrangler on another vehicle and exactly the same.
Any clues, I'm baffled at present.
For interest I even removed the flasher relay and tryed turning the indicator stalk left and right, this did make the relevant indicator slightly brighted (ignition off on Wrangler) and the dash green repeaters are two for left and right so no 'loop back' as such, like I say baffled, anyone?????:shout:
