To fuse or not to fuse ? (1 Viewer)
May 1, 2009
1,005
2,177
SOUTH WOODHAM FERRERS
Just had my 1000w inverter wired up by my dealer workshop .I already fitted the inverter in place ,they did the electrics part. It looks a tidy job with the wiring run under the van in a conduit about a 1mtr in legnth .I dont see a in line fuse,should there be one ?
Fireman Sam
1,421
2,513
Bushey
Class C
Only since 2012, but I towed for many years
It might be in a small fuse carrier where the cable connects to the battery.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Im no sparky but that sounds a huge fuse
Theory:
1000 / 12 = 83A
But in practice you need much bigger for surges.
Basically the fuse protects the wiring so if it shorts out it goes not catch fire.
So you need 100A min for the load but with heavy cables they would easily blow 200A if shorted.
150 or 200 gets my vote.
Remember, you plug in 1000W and the poor battery tries to find 100A ( remember losses in the inverter ) with a mighty "WTF is going on, 100A, you can't be serious". It won't say it for long, that you can be sure of.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
My 1800watt is fused at 250 amps as recommended by Sterling
43,320
49,404
curious Andy, what is the .75mm flat twin for.
it appears to disappear directly inside the inverter next to the right hand socket outlet.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Hi John
That's not a flat twin. The cable I believe you mean is ribbon cable to the remote inverter on off switch
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
My 1500w (3000w peak) inverter has a 300A fuse, but as I have two batteries the cable linking the batteries has a 150A fuse, working on the basis that each battery should carry half the load (batteries are identical and bought together). Seems to work.:thumb:
