To Comfortmatic or not?
Discussion in 'Fiat' started by LaMB, Apr 21, 2015.
  1. LaMB
    LaMB Funster
    Jun 15, 2012
    69
    49
    Boston
    I'm contemplating having the Comfortmatic on our new Motorhome. It's a manual box with an automatic clutch. Does anyone have any idea whether fuel consumption will be much different from a full manual? Also if you use it in manual mode can you shift gears just like a manual, both up and down the box?
    It's £1700 difference, and I quite fancy the it, but would like some feedback from those who have it already.
    Martin
    • Like Like x 1
  2. Judge Mental
    Judge Mental Funster Deceased RIP
    Sep 2, 2009
    6,782
    6,037
    Sarth London
    Try before you buy:rolleyes:
  3. Neilfg
    Neilfg Funster
    Apr 9, 2014
    482
    496
    Bucks
    We have a 2010 Comfortmatic with 3.0L, average mpg for last 12 month over 6000 miles 27.5. If we are light footed (60-65) and mainly Motorway then 29mpg, as managed on the run to Chester and back, but Peterborough was back down to 27 mpg loads of traffic and roundabouts.
    • Informative Informative x 1
  4. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,762
    39,081
    Got it.............. I prefer to leave mine in the manual position..
    I like to be in control of the gear changing when slowing...
    Have used the Auto part..... And I think it is more economical in the manual mode...
    5 ton tag axle approx 23 - 25 MPG.. with the 3 litre engine (Fiat)..(y)
  5. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,698
    11,847
    Plympton, Devon
    Fuel consumption should be virtually the same as a manual - because that is what it is. I would be wary of comparing reported mpg from different drivers with or without the auto box. Any differences will be down to driving style.
    And yes, you can drive it like a manual if you want, and even in auto mode you can force it to change up or down, which is something I do but rarely do I put it in manual but occasionally on twisty roads with changing inclines it can help to stop the box changing up and down rapidly - but this is rarely necessary.
    The only weakness I have found is changes from second to first on the move can be jerky. All other changes are silk smooth.
    But as suggested, get a test drive in one but don't be put off by feelings of panic as you approach a junction and instinct wants you to press a clutch pedal, you will I am sure rapidly get used to it. I did.
    • Like Like x 1
  6. Serendipitous
    Serendipitous Funster
    Aug 4, 2012
    322
    266
    Devizes
    Ditto 5t tag axle, however even driving modestly only does 22-23 mpg based on tank to tank. Fuel computer says 27. As its a standard dry plate clutch can't see that there should be any difference between auto & manual.
    Very pleased with the comfortmatic not designed for racing but works well, rarely used in manual. Decent engine braking.
    As others have advised take one for a spin. Good luck
  7. LaMB
    LaMB Funster
    Jun 15, 2012
    69
    49
    Boston
    Thanks for all the replies. I'm not a stranger to auto clutch boxes, as I drive modern articulated trucks from time to time, and from the replies it seems the comfortmatic is the same. My main worry was if fuel consumption was compromised. An auto box cannot see a hill coming, or hold off changing down is nearly at the top of the hill, but I guess manual override will be needed in those situations to be more economical.
  8. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,068
    DERBYSHIRE
    you will be surprised at just how good the box is I have the 3 litre with it and never need to use it in manual it knows when you are going up or down hill, it is slower and more sedate than in manual on acceleration as power is reduced in lower gears to help traction, best yet 32mpg when 50mph restrictions usually get between 27/29 depending on speed.
    If I was to buy another van it would be with this gearbox I like it
    • Like Like x 1
  9. jhorsf
    May 15, 2009
    9,156
    8,068
    DERBYSHIRE
    An example of how it knows you are on a hill is if stopped pointing up hill when you come off brake on to accelerator brake holds you for just enough time to move your foot.when pointing down hill stopped brake does not stay on as above .Clever stuff computers
  10. John Laidler
    Jan 9, 2013
    8,698
    11,847
    Plympton, Devon
    It knows when it is on a hill of course but it cannot anticipate a hill it hasn't reached yet. For example, if you are trundling along a flat road and then need to turn off onto another Road which goes steeply up hill it won't change down until you are actually on the hill. Normally this isn't a problem if it only has to change down to third or second, these are very smooth, but if you are going very slowly, as might be the case in a town and it is in second already before you turn into that steep little cobbled street, then it will drop down to first and this is a bit rough in my experience and the front wheels can momentarily skid if the surface is poor.
    This can be avoided by getting it into the right gear before you hit the hill.
    And the hill start feature is brilliant, but it is an extra, comes as part of one of the extras packs, it is not standard although it may be on the 2015 models.
  11. jhorsf
    May 15, 2009
    9,156
    8,068
    DERBYSHIRE
    Mine came as traction control hill start etc
    • Like Like x 1
  12. TheCaller
    TheCaller Funster
    Sep 23, 2013
    1,875
    2,249
    Lincs
    Pressing the UP button while still on the flat lets the box cope with that situation much better. Without it, as you say, it can get itself in a bit if a knot - just about the only time it ever does. Mind you, they could have positioned the UP button better - it's a bit awkward where it is; the gear lever gets in the way a bit.
    [The UP button selects the 'Hill' mode. The box holds the gears for longer going up & gives more engine braking when going down the other side.]
    While it can't read the road ahead, it is very good at reacting to the road it's on. I only feel the need to nudge it up or down a gear about once every hundred miles or so. (y)
    • Like Like x 2
  13. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,107
    14,921
    Leeds the one up North
    To op
    Yes
  14. Bill_OR
    Bill_OR Funster
    Dec 11, 2011
    465
    591
    Nr Hastings, East Sussex
    No hesitation - go for it! I'm delighted with mine.
