Tire Pressures
Discussion in 'Tech/Mech General' started by madbluemad, Jul 26, 2008.
  1. madbluemad
    madbluemad
    Jan 26, 2008
    3,341
    243
    spain
    Hi Folks
    I had a new tire fitted about four weeks ago. I asked the fitter to check all of the tires at the time.
    He checked them and they were all at 70 psi. The information printed on the tire says 80 psi cold. I asked the fitter to take them to 80 psi but he said that 80 was to high and that 70 was the optimum pressure.
    I have just checked my tire pressures and they vary from 70 psi to 55 psi. This may be because its very hot on one side of the van and relatively cool on the other side.
    Whats your opinion and what pressure should my tires be inflated to.
    Jim :Sad:
  2. madbluemad
    madbluemad
    Jan 26, 2008
    3,341
    243
    spain
    Please delete post, I have the answer. Unless of course its of any use to others.
    Jim :thumb:
  3. TJ-RV
    TJ-RV Deleted User
    For the benefit of others who might see this in future, the tyre pressure on the wall of a tyre is the maximum pressure. Correct tyre inflation pressure is best determined by separately weighing the four corners, or at least weighing each axle, and using the load/inflation tables on the tyre manufacturer's web site.
    Care to share that for the benefit of others?
  4. landau
    landau Deleted User
    Tyre Pressure
    I work in the workshop of a motorhome dealer (American and European) and 10psi under the cold pressure which is marked on the tyre is the rule of thumb, hope this helps .
  5. haganap
    haganap Funster Life Member
    Dec 5, 2007
    11,152
    13,977
    Heavan
    Mine are set at 70psi, exactly 10psi undr the maximum.
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,888
    17,547
    YO11 2BD
    mine are 65psi rear and 62psi front on a 2.85 tonne kontiki 640.
  7. TJ-RV
    TJ-RV Deleted User
    Some fixed number below the maximum makes little sense. If the tyres are replaced somewhere down the road by some with a different maximum pressure, do you then adjust the inflation pressure down or up even though the load on the tyres hasn't changed?
    Check the load/inflation tables on the tyre manufacturer's web site to determine the correct pressure for a given load. Here, as an example, is GoodYear's load/inflation table. Note that, in addition to the required pressure varying by load on the inidividual tyre, it also varies depending on whether the tyre is mounted single or as one of a pair (aka duallies).
    Underinflation is a recipe for a blowout, while overinflation will likely result in unexpected wear patterns in addition to poor ride and handling characteristics.
    With due respect to dealers and repair shops, I've yet to come across one that has any clue what load is being carried by tyres or, for that matter, who have heard of the load/inflation tables.
    When we bought our coach from a dealer, there was a truck weigh scale next door, although the dealer had obviously never used it. The PDI tech assured me he had checked and correctly inflated the tyres to 120 psi. I checked them (cold) and found they were inflated to 140 psi, which was higher than the rating on the rims. After weighing the coach and consulting the tyre manufacturer's table, I found the correct inflation pressures to be 90 psi in the front and 95 psi in the rear.
  8. Tony Santara
    Tony Santara Funster
    Jul 26, 2007
    1,494
    114
    Cheshire (ex Mancunian)
    Care to share that for the benefit of others?[/QUOTE]
    Hi tom
    Looks like Jim (madbluemad) doesn't want to share :Smile:
    Oh well maybe he'll want us to share info with him next time :Wink:
  9. TJ-RV
    TJ-RV Deleted User
    Tony,
    Given the nature and intent of forums such as this (i.e. sharing of knowledge, information and experience for the mutual benefit of the members), I don't understand why anyone would ask questions but not share answers. I understand even less a request to remove their question after they have their answer.
    OTOH I've been around forums many years and nothing surprises me anymore.
  10. TJ-RV
    TJ-RV Deleted User
    Here's a useful read on RV tyre care on GoodYear's web site.
  11. Tony Santara
    Jul 26, 2007
    1,494
    114
    Good link Tom
    my tyres will never suffer from prolonged storage they get used as often as i can , I have had 2 blown tyres in the last 3 years but they were degraded from use :thumb:
  12. TJ-RV
    TJ-RV Deleted User
    Tony,
    We don't worry about tyre pressures on our other RV :BigGrin:
    Weight isn't an issue either; She'll carry more than I could think of loading on board. Plenty of spare HP too, and no brakes to worry about.
  13. madbluemad
    madbluemad
    Jan 26, 2008
    3,341
    243
    spain
    Hi Tom
    Its simple, the tire pressures are printed on a label inside the coach, this is a federal ID tag that must be inside the coach.
    Ive had a lot to do with tires recently and you are correct in saying that the most accurate way to identify the correct inflation pressures is to weigh the vehicle.
    Different loads require different inflation pressures. The problems start when you have an American tire on your coach, you try to replace it and find that the US system of identification is different to the UK one.
    I spoke to the CC&C, two local tire dealers, kwik Fit, Michelin, Ford, Hankook, Gulfstream and a host of others. None of them new what the equivalent UK specification was to the US one. PATHETIC
    In the end it came down to taking some of the info from the US tire and then making reference to the coach weights which again are posted on the inside of the coach.
    Whats more disturbing for me is why did my tire pressures change by such a varying degree after only about five weeks.
    Ive invested into a good quality tire pressure Gauge so that I can now check more often.
    Jim :thumb:
  14. madbluemad
    madbluemad
    Jan 26, 2008
    3,341
    243
    spain
    That would account for all of the tires being at 70 psi when they are marked 80 psi cold. :thumb:
  15. madbluemad
    madbluemad
    Jan 26, 2008
    3,341
    243
    spain
    Hi tom
    Oh well maybe he'll want us to share info with him next time :Wink:[/QUOTE]
    What seems to be your problem then. As it happens Ive been logged off and only just seen the posts, the first one I read was from TJ and I responded immediatley. Then I read your not to pleasant piece of graffiti.
    Grow Up
  16. madbluemad
    madbluemad
    Jan 26, 2008
    3,341
    243
    spain
    SAD Try get your facts right before engaging the mouth
  17. Tony Santara
    Jul 26, 2007
    1,494
    114
    OOPS looks like we touched a nerve ...:BigGrin:
  18. madbluemad
    madbluemad
    Jan 26, 2008
    3,341
    243
    spain
    You got that one right. I will help anybody at anytime and they dont need to be a member of an internet forum
    Had you read my initial post you would have seen that I said " Leave it on if its of interest to others"
    I then left my computer. Upon my next visit to the forum I find that you have incorrectley accused me of being unhelpful and unwilling to help people or share my knowledge/information.
    This could not be further from the truth. You then led TJ by the nose and he joined in the attampted character assaination.
    Big Grins dont do it son, you can be as arrogant and as nasty as you like but not with me.
    Like I said Grow Up
  19. Tony Santara
    Jul 26, 2007
    1,494
    114
    I'm not getting into it on the forum with you it's not the place for personal arguements .
    Ill feeling could have been avoided if you had explained the answer you had found at the time you said you'd found it ...simple
  20. hawkeye6007
    hawkeye6007 Read Only Funster
    Oct 15, 2007
    13
    Fareham Hampshire
